Question about AOpen (FSP200-60SAV) 200-Watt Power Supply
We have fsp 200 60 sav smps when we start the cpu it starts and the coller fan runs for a moment and then stops and no [power could u please assist
    Genius:
  • 1,027 Answers
200 watts is not enough power - try a 450 watt supply.
Posted on May 11, 2010
I HAVE DISASSEMBLED MY PC TO CLEAR IT OFF FOR DUST IT HAS ON ITS SMPS & MOTHERBOARD. AFTER CLEANING WITH CLOTH & SOME LITTLE AIR BLOW. I ASSEMBLED IT AGAIN AND PUT THE CONNECTIONS AS EARLIER....
I'm no proffessional but when I have this problem I first think what may have caused it. Since your fan starts and then stops the power supply must at least be working. So it may have been something like your static electricity confusing the motherboard or something weird like that. It could also be that you tried to boot it up with some connection with the negative plugged in the positive and visa versa...that shouldn't cause much of a problem but you may want to research your motherboard and make sure it has the safety mechanism.
Anyways, I think the best thing you can do is remove any extra memory ram sticks you have and unplug all USB and the PW SW and all that and even the main power supply and then plug it all back in. Good Luck
Feb 27, 2011 | Gigabyte GA-G31M-ES2L Motherboard
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using...
if your power supply is good and has DC output.....i have encountered a leaky capacitor at motherboard near the power supply connector socket...need to replace it esp. if it manifest bulgy appearance..it is a electrolytic type, replace w/ same value, it does affect the power to supply the MB due to fluctuation......try to test run after replacing it..have a nice day...
Feb 12, 2011 | Mercury P4VM800M7 Motherboard
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
My new cpu can't start
I think there was some hardware issue in your CPU,if RAM is unplg or loose in that condition CPU will be not working,Replug the RAM properly and start the system if still cpu not working thats mean there was a problem with your cpu SMPS fan (place backside in cpu for cooling),cpu fan SMPS is not support,Please change it.
good luck..
Please rate me....
Thanks
Mar 25, 2010 | Sony VAIO PCV-W600G PC Desktop
When i power on cpu fan start initially and then sop
try to change your fan proccesor or your power supply adapter for your CPU
Mar 12, 2010 | ASUS M2N68-AM SE2 Motherboard
My Dell Demension 2300 will not power up.
open cpu cabinet then refix RAM.
Reattch all connection to motherbord also check your smps power unit works fine.
may be your smps is gone .
SMPS is aquare box which with you connect power code.
Jul 29, 2009 | Dell Dimension 2300 PC Desktop
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
Cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Oct 03, 2008 | Intel Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
AOpen (FSP200-60SAV) 200-Watt Power Supply Logo
321 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Iqbal Husain
Iqbal Husain
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
