Question about Qca Spas Majestic Series Aruba Xl Hot Tub
Does a Nature 2 work in these hot tubs? - Qca Spas Majestic Series Aruba Xl Hot Tub
  • 717 Answers
Absolutely! Nature 2 will work with any hot tub.
Posted on Sep 06, 2010
Do I access the tub area from the front panel or the top?
The 5500 Neptune washer and all predecessors are accessed from the front. by removing the 2 hinge screws, and the opposite 2 screws. The front goal post panel can then be removed, then the door can be lifted off. Maytag made a 1 piece tub and a removable front tub cover. Once the tub cover is removed by pulling all the tension clips you can remove the stainless spin basket one of 2 ways, either remove all 3 of the basket tumblers, then the 3 basket bolts, then the basket can be removed leaving the spinner support behind, or you can remove the rear panel, then the main pulley, then tap out shaft with a 2X4, this will remove the basket and spinner support together. You have not described the nature of your leak. Pleazer Appliance...
Apr 27, 2014 | Maytag Neptune MAH5500B Front Load Washer
Hot tub wont come on
What do you mean "Jump it"?
Check with a meter, ACROSS both hot wires to get a reading of 220-240 volts. do not test across 1 hot and the meter lead on ground! You probably are not getting proper voltage to the hot tub. Or you may have a burned system fuse normally 20-25-or 30 amp fuse, which is found within the control box of the spa.
Jan 06, 2013 | Balboa Instruments Duplex Digital Panel 2...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
The hot tub is no longer heating
There are two main items to check. I do not recommend them unless you are qualified to work with electrical. The 2 main things that this could be are:
1. Pressure switch failure( (hot tubs need a sensor to tell the computer when it is safe to operate. If the pressure switch is out, then it will not heat) if this is a hot tub with a 24 hour circulation pump, then the pressure switch would actually be a flow switch.
Fix: Replace pressure switch/ flow switch
2. Heater element failure. (This type of failure typically trips a GFCI breaker)
if the heater element is out, then it will short to ground causing the hot tub to shut down repeatedly.
Notes: Are there any trouble codes coming up on the display panel? these help out greatly when troubleshooting like this via- messages
Oct 21, 2010 | Qca Spas Paradise Series Paradise Supreme...
Gfi Breaker 2 Pole 20 Amp: installed 20 amp dbl pole breaker to hot tub. Keep...
When Working with Household Electricity you want to always keep in mind that the BLACK wire ALWAYS carries DEATH. What I mean by this is that working with a Single Phase Circuit (one that uses 120VAC) the only wire that should be carrying a voltage is the BLACK one, the other 2 wires (typically the White Neutral and Green Ground) should both be electrically connected to Earth Ground (usually by being attached to your water pipe.)
It is also possible that your hot tub may use more than 20 Amps.
May 17, 2010 | Cutler Hammer Gfi Breaker 2 Pole 20 Amp
Hot tub breaker not tripped but nothing works
Sounds like your controller has sustained damage. You need to have a professional inspect it to determine what has gone wrong.
Apr 14, 2010 | Pool & Spa
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Bath tub water doesn't stay hot
it is because the tub has a temp control valve in it so if you were to put more cold with the hot it will last longer but still won't be all the way hot,, now a days people are suing the manifacture because they are getting burned form the hot water so they put these saftey temp controls in place of the old style 2 or 3 handle faucets,, there fo no more real hot water nothing you can do outside of change to the othere type of faucet 2 or 3 handle tub shower diverter,, that why the water is hot in the sink but not the tub.....
Jun 23, 2009 | Water Heaters
Foam in hot tub cover broke
The foam in there is available at most insulation or drywall supply houses. It is used for insulating concrete walls, the cover is probably 3 inches thick so you may have to buy 2 sheets to get the thickness you want. The only issue is the cost of the foam may not be much less than a new cover.
Mar 11, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Jan 10, 2009 | Home
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
87 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
