Question about Brother MFC 420CN All-In-One InkJet Printer
My printer is printing fuzzy, Why? - Brother MFC 420CN All-In-One InkJet Printer
It is printing but the lettered is fuzzy
Best practice is to indicate device, brand, and model when querying about printers. Solutions vary by such often.
The blurring could be caused by the type of paper being used. Or, too much paper being in the printer. It can also be caused by substances adhering to the ribbon (where one is part of the setup). Then there is a potential problem with a fuser in a laserjet.
For example:
Printed documents print ghosted blurry grainy doubled or with smudges What...
How to Solve Common Printer Problems
Fuzzy Print HP Laserjet 4240 4250 and 4350 Printers
Aug 28, 2017 | The Office Equipment & Supplies
Barcode prints fuzzy
Have you tried to "clean" the printerheads. You know like you would do with a normal printer. Sometimes the printheads go stucked with old ink(wich you cannot see on screen ofcorse)
Apr 16, 2014 | Zebra GK420D Direct Thermal Label Printer
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
Pinting appears to be fuzzy and not clear
Adjust print quality in the settings for the printer whenever you go to print a picture or something. If that is not the case then you might need to change the ink. Low ink might cause incorrect color mixtures and the images could appear fuzzy.
Mar 04, 2011 | Brother MFC295CNAll-In-One InkJet Printer
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Fuzzy ink
probably dirty or broken print head. suggest you replace it or get new blue cartridge if your machine has seperate colour cartridges.
Jun 17, 2009 | Brother MFC-5440CN All-In-One InkJet...
My printer prints fuzzy
Have you tried to do an alignment? It's usually part of maintanance.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Fuzzy printing brother MFC 5890cn
check interface cable and load proper printer emulation language
May 01, 2009 | Office Equipment & Supplies
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
210 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
