Question about GE Profile 30" Telescopic Downdraft System - Black
My downdraft system does not work. It does not come up when when I push the button. Also, when I plug the unit in, it makes a whining noise.
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Posted on Jun 01, 2008
SOURCE: JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Posted on Sep 01, 2011
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
Continous whine sound on APC Surge Protector 600
Hello Glen,
Yes, The batteries in UPS systems have a 2.5 to 3 year life span so your unit does need new batteries. The whine is usually caused by the charge circuit trying to push the charge to the damaged cells in the battery. You should be able to get replacement batteries from your local battery dealer, no need to order "special" UPS batteries. Open your UPS cover and remove the old battery and bring it to the dealer and they will match it to their stock.
Jul 19, 2012 | Computers & Internet
I have a Broan 2736 Eclipse downdraft blower system. When I push the button the downdraft rises but then immediately goes back down
Gail was spot on. That worked for me until the unit would go up and/or down on its own. The problem was traced to the double microswitch called the 'Lower Switch Bracket Assembly' ($24. thru Lowes ). To replace these switches is not for the faint of heart as it is deep within the assembly. A good weekend mechanic can look at the exploded parts diagram and see what / where. Found grease residue on- and slightly within- the microswitchs due to Broan not properly design shielding and protecting these critical switches from grease. Did not find any ghosts, however.
Nov 08, 2010 | Broan-NuTone 273603 Kitchen Hood
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
Whirlpool dryer will not start
open top panel should flip up two screws at lent trap screen if on top of unit when top panel is up push start button then push drum while you hear that buzzing noise if drum starts it needs a new motor
Feb 21, 2009 | Kenmore 63942 Dryer
Whining noise @ acceleration?
You have a bad ground somewhere. You also may nneed to replace your spark plug wires. The deck is getting interference from the engine due to a grounding problem.
Best of luck
Jan 30, 2009 | Panasonic CQ-C3301U CD Player
Pivot arm in telescoping downdraft system sticks when closing
Having the same problem. Unit worked well for 1 1/2 years and then suddenly it dropped after I was thru using it and pushed the arrow for it to go down after it dropped the power wouldn't turn off - had to unplug it.. Repairman came out , took it out, lubricated it , re-installed and next time it went up fine, vented fine but when it went down it dropped again and power wouldn't turn off again. I am hesitant to call him out again unless I can figure out what else might fix the problem. I have noticed that the top piece now seems to be bowed a bit. I guess I can have him take out the cooktop but think there must be enough room for it if it worked fine for the 1 1/2 years. It is a soapstone countertop.
Dec 28, 2008 | GE Profile JVB67 36" Telescopic Downdraft...
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Goldstar MV1526W over the range microwave
We actually have the service manual available at our site:
http://www.microwavedisplay.com/mv1526_sm.pdf
That should help you or a friend check and diagnose it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 10, 2008 | Goldstar MV-1526 Microwave Oven
GE Profile 30" Telescopic Downdraft System - Black Logo
75 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
