Question about Lexmark P4350 All-In-One InkJet Printer
My scanner has a faded image down the page
Scanning great until now, when there is a half inch wide strip not scanning properly about two inches from the edge - can it be repaired? Bill R
  • 3,083 Answers
It probably can be repaired, but get an estimate first- parts and labor can add up. Call a couple authorized repair shops to get a ballpark figure. The cost of some repairs sometimes justifies just going ahead and getting a new one. Wish I had an easy answer for you, but hope this helps.
Posted on May 10, 2010
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Have a Phaser 6110 MFP. When I scan a page using the ADF I get 3 color lines running vertically down the image. If I don't use the ADF, the page scans without the lines. What could be causing this?
There are some small spots on the "seal" glass. It is the 3/4 inch wide strip under the scanner, not the main glass. Clean that strip well, I suggest taking some rubbing alcohol and just a regular piece of paper, crumpled up. Use that to clean that strip vigorously.
That will take care of it.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Line Across Page
There could be something on the scan glass. You have to open the cover on the scanner and look across the scanner glass. It is only about a half to an inch wide strip that the original passes over.
If there is nothing on that glass then some of the segments in that array have gone bad and it would need to be replaced.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
No image is displayed
lift the scanner cover about half inch to see. check your usb cable.
Sep 19, 2007 | Nikon LS 2000 Film Scanner
Lexmark P4350 All-In-One InkJet Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
