Question about Zonet ZFS3008P 8x10/100 Mbps Networking Switch
Which port do i plug in the ethernet cord from the modem. Zonet ZFS3008P and does any one have owner manual
  • 472 Answers
It is basically a switch so if you are planning to connect more than one computer using this switch than you need to connect a router in between modem and switch
modem -- > router -- > switch -- > computer
from your modem an ethernet cable will connect into an internet port on the router and than from LAN port of a router cable will connect into any port on your switch.
Let me know in case if you need more help :)
Posted on May 19, 2010
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
How to reinstall
Wi-Fi connection will afford you greater latitude in Internet use.
Wires will not be necessary, so you can establish your PC in any room or area of your home or office and still stay connected to the Internet.
Fortunately, you only need a wireless router, broadband modem, and ethernet cable to make this Wi-Fi connection.
Disconnect your modem from the wall socket it's plugged into.
Connect the ethernet cable to the back of the modem.
There is a clearly marked ethernet port here.
This port will appear to be an oversized telephone jack.
Connect the other end of the ethernet cable to the ethernet port on the back of the wireless router.
This port will look exactly the same as the one on the rear of the modem.
Plug the broadband modem back up to the wall socket and wait for it to power on, initialize and detect its new connection to the wireless router.
Locate the manual that shipped with your wireless router.
Find the URL, or web address, that is contained within the pages of this manual.
This special web address is used to set up your router's network and security permissions.
Also, be sure to locate the default password provided within the pages of the manual.
Enter the URL into your web browser and allow the page to load.
When prompted, enter the password that you found within the instruction manual.
Begin setting up your new wireless network.
You will be asked for an "SSID," which is just a moniker for your new network.
This will be the name seen when the network is listed in an available network list.
Choose whatever name you like.
Select a password for your new network.
While encrypting your network is optional, it is highly recommended. Along with the password, choose "WPA" security encryption.
"WEP" will also be an option but it is an older security protocol that is technologically inferior to WPA.
Click "Apply" to save your changes.
Click on the wireless icon on the right-hand side of the bottom toolbar on your PC's desktop. Select your network's SSID from the drop-down list.
Enter the password you chose for your network.
You will now be connected to WiFi Internet on your PC desktop and free to browse the Web.
http://static.highspeedbackbone.net/pdf/Z165-1302-Zonet-ZSR4154WE-Wireless-Broadband-Router-User-Manual.pdf
May 20, 2013 | Zonet ZSR4154WE Router
I need to lock my router from others using my wifi
    • 1 Disconnect the power cord from your high-speed modem. Locate the Ethernet port on the back of your modem. If an Ethernet cable is already plugged in, trace the cable to the second device and unplug the cable from it; otherwise, plug one end of an Ethernet cable to the open Ethernet port on your modem.
    • 2 Plug the unused end of the Ethernet cable to the port on the back of the router labeled "modem." Plug a second Ethernet cable into one of the open ports located above the "modem" port; connect this cable to the Ethernet port on your computer.
    • 3 Reconnect the power cord to your modem; wait for the lights on the front panel to turn green before proceeding. Plug one end of the router's power cord into the corresponding port on the back of the device; plug the remaining end into any available electrical outlet.
    • 4 Turn on your computer and log into your operating system as normal. Insert the installation CD into the computer; the installation application should load automatically (if it doesn't, you can find the application by manually browsing the CD's contents).
    • 5 Follow the onscreen instructions; after you have made the initial configurations, click on the option labeled "Security Assistant" on the left side of the installer window. Select the desired security type for your wireless network and click on the button labeled "Next."
    • 6 Choose a network key and enter it into the appropriate field; press "Next" and follow the onscreen instructions.
    • 7 Open your computer's wireless network settings and enter the wireless network name, security type and network key into the appropriate fields. Save your changes. Set-up is now complete.
Tips & Warnings
  • You can access additional settings via the modem's manual configuration interface. Open your web browser and navigate to 192.168.2.1; when prompted for a password, leave the field blank, and click on the button labeled "Submit."For optimal signal strength, choose a location for your router that will be near your computer, with as few walls and other obstacles as possible.
Read more: How to Set Up a Belkin N F5D8236-4 Wireless Router ' eHow.com http://www.ehow.com/how_5106168_set-belkin-fd-wireless-router.html#ixzz1ONVtjSQ1
Jun 05, 2011 | Belkin F5D8236-4 Router
What port to use with ethernet cable
Hi all of you i see an app for iphone and android phone Ethernetpedia.which is i think very help full.which solve all your problem. port-use-5bezvpwuytf0bd1jcum4m4zn-3-0.jpeg
May 03, 2011 | Computers & Internet
I need to know where to plug the big yellow phone cord. One end goes in the top plug in the back of the router and where does the other end go? In the back of the motorola motem? What else is supposed to...
The cord you are referring to is a CAT5 network cable. The color isn't important, but they usually ship the routers with color cords to help with the installation. Typically you would have the following setup:
1. A CAT5 network cable that runs from your broadband modem TO your Belkin Wireless Router in the "Internet" port. (Port "a" in the diagram)
2. Now plug another CAT5 network cable in to the back of your computer's Network Interface Cord TO one of the remaining ports on your Belkin Wireless (Any of the port "b" in the diagram).
However, you will need to run the configuration software that come with your router.
Please let me know if I can further assist you.
Regards,
KYTechnology
Mar 02, 2011 | Belkin Basic Wireless Router
How do i install a router
Use quick start guide. If not plug in router. run USB cable (should come with one), or run cat5 (ethernet cord) from modem to router. then run ethernet cord from PC to router. Plug cord from modem to router in first port. plug cord from PC to router in any other port. Should be good to go If you have a software disk you should run it first and it should prompt you with instructons.
Good luck
Oct 15, 2010 | Computers & Internet
Only 1 PC will work at a time on this router,
no.... Can I be of some assistance. I need the model number and manufacture of your router
Jun 16, 2009 | Zonet : ZFS3008P 8-port 10/100Mbps...
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
How to install zonet into surf board?
If the Zonet device is a router, then yes the Ethernet cable should go from your surfboard modem to the WAN port on the Zonet device.
Mar 18, 2009 | Televison & Video
Zonet ZFS3008P 8x10/100 Mbps Networking Switch Logo
140 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
