Question about Maytag Neptune FAV6800AW Top Load Washer
FAV6800AWW is very loud in the spin cycle only, the basket does move freely and the belt is in good condition. the noise does not seem to be from the clutch,
  • derek_martin May 10, 2010
    the first digits of ser# are 12
    it is not a grinding sound but rather a loud "whirring" noise when it is in spin cycle. i am not sure it will free spin several revolutions, about one time around is it. many thanks.
    derek
  • 526 Answers
Derek,
What are the first two digits of you serial number of you FAV6800A or FAV9800A? It will digits 10, 11, 12,thru 17.
In spin Cycle the Wash Basket rotates in the Outer Tub bearings in the CCW direction. I1f you spin the wash basket CCW by hand as fast as you can the Wash Basket should cost several revolutions to a gentle stop. Does it?
Do you hear and bearing noise/grinding sounds as the wash basket coast to a stop? If so I would drop the clutch out and inspect for traces of a Tub Seal leak.
My Clutch Fix will help you disassemble and let me know if can help. I have …….Rich
Posted on May 10, 2010
Testimonial: "the quick response is extremely useful to solve your problem FAST!"
  • FAV6800A FAV9800A
    FAV6800A FAV9800A May 10, 2010
    I woud say you have bearing drag from the description. If you spin the wash basket thru the lid CCW as fast as you can and you only get one revolution I fell you have severe bearing drag.
    A post where I recently replaced the Outer Tub bearings in a Series 10 FAV6800A Issues with Outer Tub Bearings
    It can be done I'm a an average DIY'er
    I would have suspected unbalance issues before the bearing noise started up if it is bearing noise. Have you failed in Spin Cycle with unbalance error code of dC or uC?
When it goes into the spin cycle it makes a loud knocking noise like a gear or belt is bad. what can i do, it is only 1 1/2 years old.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.If the bearing is getting out of its way then its faulty weak motor causing this.Check out both the bearing and the motor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Suspension plate
The suspension plate should be loose and float between the frame and base. The pin you saw was a shipping pin, they usually are caught in a little plastic cup attached to the base but sometimes fall to the floor, this is normal too. The tub being loose is normal for the top, it is held down by the springs below the tub but nothing on top. By a loud noise, what kind of noise is it? If it is a very loud ratcheting noise when it slows down then the basket drive(spin tube) and block need to be replaced. If it is a growling noise then that is pump and may be normal if the basket is not spinning. If this is the case look very close for an article of clothing caught between the tub and basket.
Apr 19, 2010 | Estate TAWS800JQ Top Load Washer
Whirlpool mach. is humming when u turn on but agitator won't move
Hello friend,
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
In case of the agitator not moving check the following:
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
Check the above, It seems that your washer needs a repair and would not be possible to do it yourself. So yau will have to call a technician.
Do feel free to get back to us in case of any other assistance if problem is not solved or if you have any other query.
Thanks
Mar 05, 2010 | Whirlpool Washing Machines
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Stopped spinning after making loud noise.
First check if the motor is lose, if ther touting is in place, if some bolt is lose, or if there is any broken part. You can see this at eyesight.
When washing machine vibrates in this way usually you need to replace thrust bearing, see this document and also this one here
If you insert right model number here you get exploded view and parts
Sep 02, 2008 | Maytag Performa PAV3200
Loud noise, then not so loud, but now electrical burning smell and little draining
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
398 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
