Question about Whirlpool GEW9200L Electric Dryer
I have a Whirlpool Duet Dryer Model GEW9200L and it's not working. The panel lights up, but when I hit the "start" button, it makes a clicking sound and it beeps, but won't turn on. Can this be fixed easily?
  • morin67 May 12, 2010
    Thank you for you help, but we figured out the problem. The thermal fuse just had to be replaced. I'm so happy it was quick fix!
On a Whirlpool Duet Dryer is the thermal fuse on the houswing where the heating element is? mine has 3 different fuses or sensors on the heating element houseing which on is the thermal fuse?
Posted on Nov 30, 2010
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerI have a Whirlpool Duet Dryer Model GEW9200L and - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
My Duet Dryer starts runs a minute or two then beeps two or three times and stops. The display lights flash, if I push start it starts again but then stops again after a minute or two. I've gone t
I would first unplug the unit and remove the top cover. There are 3 screws towards the back of it. Push the cover back towards the wall and pull off. To the left you will see a control panel (usually black metal case), remove the 3 screws and flip over so you can see the control. Make sure there are no loose connections. I have ran into quite a few that had relay connection wires loose. If everything is ok. The next thing you would want to do is remove the front lower access panel (kick plat panel) and blower chamber. There is a thermal fuse and a thermistor located behind it. If you have a meter then take the proper continuity tests that are displayed on schematic. Both the thermal fuse and thermistor are fairly cheap. Click Here for a link to a thermal fuse on a Whirlpool Duet Dryerefd097de-8d08-43d9-8d3d-9f8b17924fb9.jpg
Apr 01, 2013 | Whirlpool GEW9200L Electric Dryer
My Duet Electric Dryer control lock light on and will not turn off and dryer will not start.
I had this happen..push and hold the signal button for about 3 secs this should unlock it. Thats what worked for mine.Good luck hope it helps
Jul 17, 2010 | Whirlpool GEW9200L Electric Dryer
Duet dryer makes noise while starting
Your belt or idler pulley may be defective. Click on link below and enter your model number GEW9200L into the model search feature, We also offer free assistance and help to your answers.
Click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 28, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
all the lights are on but when i hit the start button on the dryer it just clicks any idea why this happens
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Jun 14, 2008 | Whirlpool GEW9200L Electric Dryer
MY CONTROLS ARE LOCKED
Press and hold the End of Cycle button for 3 seconds.
Jun 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
523 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
