Question about Denon AVR-589 Receiver
When I turn on the receiver, I can play music through it any where from a minute to 6 minutes. After this amount of time passes there's a pop like sound that sounds like some kind of electric issue and then it switches to stand-by. It sounds like maybe it shorts or something.
  • aperedia May 10, 2010
    How exactly would I change the voltage on the unit?
    I have some kind of electrical problem with my unit. When I engage it from stand-by to on I can play music on the VCR/iPod setting for a few minutes before it makes a pop like sound. It sounds like an electrical issue though I am not sure what it is. The unit then switches back to stand-by. I have had the unit for at least a year and a half and it never had this problem before.
  • 3,083 Answers
This is probably a capacitor or regulator in the power supply, in one of the main supply voltage lines. That circuit gets a lot of stress, over time, and electrolytic capacitors can dry out, and become faulty. This is most likely a temperature problem (the capacitor, or sometimes a regulator IC) since it happens a bit after you turn it on. These type of problems can be located by using Freon (cold spray). You let the unit heat up until it messes up, then spray components, one at a time. When you hit the bad component, the circuit will come back on. This could be a cracked trace, that makes contact when it's cold, but heats up and expands after a bit, losing contact. This type of problem is typical of the transformer and main power circuits. The power supply has an overload circuit that automatically cuts the power off, to avoid damaging other components, burning things up, etc. I had a Kenwood once, and it's problem was the main transistor in the amplifier circuit, but that was years ago- today's systems use ICs and regulators, for the most part, so they would be the likely suspects. Good luck- hope this helps and gets it working again!
Posted on May 10, 2010
    President:
  • 1,469 Answers
Hi, What causes a receiver to switch to stand -by mode is, when the voltage of the light you are using on it is a little lower than it, and can not really power it for too long that is when it goes off and back to stand-by mode.
You need to get your voltage system, it needs more light to power on successfully so that it will not strip off again.Change the voltage of the receiver, if you a big generator, you can also try it out with it and see if it will go off.
When you rectify the voltage level of light you are using, it will work properly.
Take care.
  • Egwe Emmanuel Onyedikachi
    Hi, there is something you most know about electronics, current affects it very well. It can fluentuate and affect electrical appliances. Especially when too loud it strips off.
    What you need to do is that you check the transformer of the receiver to another one that can suit the current in your apartment. am sure that is what is affecting it.
    If you can check it your self, you can take it to a near by repair store around you, in other to prevent further damage.
    Take care.
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
I have a lg dvd receiver 503th and when i try to play any dvd the image of the movie leave turning the tv into a black screem and after 3-6 seconds the image comes back. this happens along all the movie...
Try configure the color system that apply to your country or clean the lens gently by using soft cloth and a little amount of isopropyl alcohol. Apply a little amount of alcohol unto cloth and gently wipe the lens and try play your dvd
Jan 12, 2011 | LG HT503TH Theater System
No sound from front left channel
Hi, here is a procedure to discover the source of the problem. No sound from the left front channel can have several sources other than the left front channel itself.
Let's assume, for just now, that the speaker is good and the cable to it is good.
Here is a testing sequence to follow:
1 If you have a CD player connected to it. Put a CD in and put it into play mode.
2 reverse the connectors from the CD player to the receiver. See if the sound moves to the left speaker and stops on the right speaker. Or if it plays fine.
3 If the sound reverses channels, That cable is bad. Replace it
4 If the sound is still not coming from the left channel. Check the connections and cables to the speaker. MAKE SURE THERE ARE NO STRANDS OF WIRE TOUCHING THE CHASSIS OR SHORTING TO THE OTHER SPEAKER WIRE.
5 If there were. Correct it. Shut down the receiver and then after a few minutes turn it back on.
6 If it still does not work. check to see if a tiny amount of sound is coming from the left speaker.
If so, turn the music up and see if it pops back on . If that is the case there is a failed resister on the circuit board that is arcing when you turn up the volume. That being the case, it is time to drop off the receiver to be repaired in the service center.
Hope this helps,
Best,
Mark
Jan 04, 2011 | Harman Kardon AVR 330
Receive shuts it's self off while playing music
you either have the polarity crossed on one of your speakers, one or more of your speakers are blown or maybe one of your wires are cut
Oct 26, 2009 | Audio Players & Recorders
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
My Kenwood amplifier is having problems, whenever i turn it on. all seems well until i play some music through it, after 30seconds to a minute the music will cut off and a distinct click is sometimes...
Your amp is going into protection. The click you hear is a relay meant to protect your speakers and stereo. Check your speakers with an ohm meter for the the proper ohms ( listed on the speaker ) and physically try to push each woofer and midrange cone in gently to make sure it moves and is not stuck or frozen in place. A speaker may read correctly on an ohm meter if the woofer is ok but if the tweeter or midrange is not working it will cause the amp to go into protection mode. When you play music stick your ear up to each tweeter\midrange\woofer to ensure they are working.
Your stereo could also be the culprit although usually if it plays music it is ok as long as you are not hearing loud pops. Loud pops are voltage spikes that indicate that a transistor\IC is breaking down and will eventually short. Good luck!
barneyluc
Oct 01, 2008 | Audio Players & Recorders
KLH R7000 "popping"
what input u on were pops dish ? cheak audio out settings on dish box to pcm or uusing digital cable then use dobly digital
Feb 09, 2008 | KLH R7000 Receiver
Turning off
upgrade to the latest firmware
http://us.creative.com/support/downloads/
Jan 08, 2008 | Creative Labs Zen Micro MP3 Player
Poping in speakers
Same issue with my AVR-589...2-15 minutes after sound is playing (via TV or DVD). I checked all wires and speakers. Even reconfigured to audio only (analog) coming in, same issue. Put my old Denon receiver in and the problem disappears...possible overheating issue with this new unit?
Dec 22, 2007 | Denon AVR-3806 Receiver
Denon AVR-589 Receiver Logo
63 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
