Question about Kenmore 24032\24036 Top Load Washer
My kenmore washer model 110.29822800 is not filing water
    President:
  • 1,937 Answers
First, see the Sears parts list for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.29822800&pathTaken=partSearch
Look at the section on the Rear Panel parts where you'll see the components for how water enters the machine.
A bad question but are you sure that the water is on going to the machine? (I've done it myself)
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive machines. It has a description of how the washer works as well as testing procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It sounds like a problem with the level switch or inlet valves.
Posted on May 10, 2010
Where is the water level switch or censor on washer model number 11024632300
See the following documents / sites:
First is the Sears Parts Site for your washer with diagrams and parts / prices:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024632300/0582/0153200?pathTaken=
Second is the Whirlpool / Kenmore Service Manual for top load, direct drive washers with diagnostics, testing and troubleshooting sections:
Third is an illustrated description of how to release the console and remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
The water level switch is in the console.
Nov 21, 2010 | Kenmore Washing Machines
.how do you remove the water temp knob from this
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082873810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts. Look at the section on the console.
Next see the following for how to release the console for access to the knobs / switches.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6b1f4b747e3f6a996f7dbf25034cd5f4
Also see the following Whirlpool / Kenmore Service Manual for these washers.
Nov 14, 2010 | Kenmore Washing Machines
I have a Kenmore 90 Series model 110 washer that overflows. I have changed the water level switch and verified the tube is clear and has no leaks. Could the timer have anything to do with the problem or...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
It has a troubleshooting section as well as testing procedures.
I'd test and verify that the Water Inlet Valve is working.
If it tests OK, I'd also test the timer.
May 19, 2010 | Kenmore Washing Machines
Water-level switch shorting out
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
It has a section on testing components including the water level switch:
See the following for how to release the console and cabinet.
Apr 23, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
Mar 26, 2010 | Kenmore Washing Machines
Hot ware trickles in on my Kenmore Series 80 Model 110.92282100. I probaly need to change the water valve. How do I get access to it?
First, see the Sears Parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92282100
By looking at the diagrams, you should have a good idea of how to access the water inlet valve.
See the following for how to access the console.
This is the Whirlpool / Kenmore Service manual for top load, direct drive washers.
Dec 20, 2009 | Kenmore 24902 Top Load Washer
Kenmore 70 series model 22722100 won't fill with water
First see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.22722100
Also see the Whirlpool service manual for top load, direct drive washers.
If you're sure that the water is on and there are no obstructions in the hoses, I'd check the "water level" and / or "water temperature" switches.
See the Whirlpool manual for how to test them.
Nov 01, 2009 | Kenmore 22422 Top Load Washer
Where can I find a repair instucton manual for a kenmore series 90 washer?
Following is the Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
Following is the Whirlpool / Kenmore parts list for commercial washers although the consumer model is basically the same.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 18, 2009 | Kenmore Washing Machines
My Kenmore 26962 Washer will start its cycle once
check you lid switch
most machines will not go into the cycle
if that switch is bad
some models have a tab on the lid that dresses this swich when you close the door
but with out the proper model number i cannot help you more sorry
Oct 09, 2009 | Washing Machines
Kenmore Series 80 top load washer Cold water trickles in. I have checked water line in and tiny screen where hose attaches. No problem. It is somewhere inside the machine that the flow is cut off. Any...
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
I'd also see the following PDF on Whirlpool / Kenmore top load direct drive washers. It has a description of how they work and troubleshooting sections.
The problem sounds like one of the water control valves or switches, (assuming that you've verified that the hoses to the washer are turned on.
Oct 06, 2009 | Kenmore Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
637 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
