Question about Maytag Neptune MAH5500B Front Load Washer
My neptune washers drum wont move could it be a belt the cycles seem to work but after it fills or after it has removed the water it just sits there and the drum dosent move
  • 1,557 Answers
It could be a belt but in that case you would still hear the motor running if not then the gear box is locked and will need to be repplaced
Posted on Jul 06, 2010
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
Our Maytag stacking washer/dryer, MLE2000AYW, has generally worked well. Recently there is water in the washer after the clean clothes have been removed. The water can be removed by adding a spin cy
The intake valve may have debris under the plunger allowing the water to bypass the valve. If it fills up when not in use it is a sure sign of this. However, your issue sounds more like a clogged filter allowing drain water back in the drum after the cycle has ended
May 19, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
There is always water in the drum even after a laod but after it sits empty the tub fills with more water
This might be a problem with your locking mechanism which is preventing the washer from actually performing a complete spin cycle. It will drain and appear to function but the high speed spin never actually takes place.
Aug 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Clothes are still soaking wet after spin cycle and the wash cycle is complete.
Sounds like your bearings have gone in the back of the drum and damaged your water seal. the clay type substance is possibly water mixed with grease.
Mar 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
