Question about Amana Refrigerators
The red filter light is on,on our Amana refrigator. We changed the filter and the light is still on. What should we do?
  • wpz4658 May 10, 2010
    It worked! Thank you very much I was unable to find the manual on the refrigerator.
  • 4,070 Answers
Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Posted on May 10, 2010
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
How ti reset water light
From the ones I'm familiar with you press and hold the lock button and light button for 5 sec. Not sure if its the same on all.
Jul 08, 2013 | Refrigerators
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I changed the water filter and I can't change the red indicator light to green on the outside of the refrig. Help!!! Maytag side by side
AFTER CHANGING THE FILTER . YOU THEN HAVE TO HOLD DOWN THE LIGHT BUTTON AND THE LOCK BUTTON AT SAME TIME FOR APPROX 3 SECONDS AND THE FILTER LIGHT WILL FLASH THEN GO OUT
Dec 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
I cannot find the Water Dispenser filter. The red light alerting me to change the filter has come on and I am at a total loss. Please help.
inside the fresh food side in the back at the top shelf. filter is round and twist out and new one twist in . easy job to replace / the part # for your model is 12527301 ( orher # is WF401S ) EITHER # IS SAME FILTER .. . THANKS **** HOPE THIS HELPED ..
Jul 22, 2010 | Amana ARS266ZBS Side by Side Refrigerator
How do i get the red light to go back to green after i have changed the filter. Amana side by side 22 cu.
you have to hold down the filter status button for a long time (like 10 seconds) until it turns green.
Aug 26, 2009 | Amana Refrigerators
I cant get my refrigerator unlocked
Hi: I don't know if you have the manual, but you have to hold down the lock button down for several seconds to release it. That how it works. I hope this helps and you don't need service. As a last resort unplug the fridge for an hour ( don't open it in the interim) then plug it back in and see if it resets. I hope this helps, Jeff
May 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
Where is the water filter in the bottom freezer amana energy saver model refrigerator; and how do you change it?
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
Feb 17, 2009 | Amana ABB1927DE Bottom Freezer...
Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Nov 10, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
14 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
