Question about RTO 12v 70ah Leoch Battery For Scooter Or Wheelchair
Scooter wont work. Charger shows "Green"......its been sitting for months. Just found the charger. When throttle is rolled on it makes a high pithched tone but crank wont turn the wheel...
  • 177 Answers
Hi. I have had a few cases where the machine has been sitting in a damp room and the brake has rusted to the body and wont release. A few light taps with a small screw driver has usually fixed this. You will need to put the machine into free-wheel before doing this.
Could also be a faulty brake unit, that has seized up.
Try pushing the machine in free-wheel mode to see if the motor and drive wiil move.
Normally if there is an electrical fault with the brake assembly, then the machine will have a fault code on the display. good luck. Neil.
Posted on May 29, 2010
Batteries ran completely down now fully charged scooter wont work.
hi if youre batteries have been sitting for 18 months without a charge they r probably no good now after batteries sit for a long time the plates develop a coating & when u do charge them the they will not charge properly..youre charger guage is not a true reading the only way Is to use a battery LOAD tester this will give u a true reading on the condition of youre batteries...u can buy a battery load tester of e/bay for aprox $35 ........
Sep 06, 2015 | Golden Technologies Companion II Travel...
Wont charge up, batteries showing between 3 and 4 volts, batteries less than 12 months old. Charger ok brand new
The batteries are to low for the auto charger to work so either replace batteries or have them load tested to see if they are any good. Personally I would replace them.
Apr 09, 2015 | Health & Beauty
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Will a battery charger with too low a rating hurt my scooter? I just found out that the batteries in my scooter are slightly larger than the rating printed on the charger. It seemed to work fine...
hi, if the blinking light never stops blinking that can imply a fault with the charger but first make sure the connections to the batteries are clean and tight.
Dec 19, 2012 | Ctm Health & Beauty
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Hi I have just been given a loan of a heartway mobility scooter. It was only used once but the lady found it to fast so it has been packed away for 2 years. I sent it off for new batteries and a service...
Willis try plugging in the charger and charging overnite tonite. In the morning check the charge and see if you get more than 3 bars. Also look at the charger light and see if it has turned green. If it is green then the lights should all be lit, if not then you could have received a bad battery. after charging all nite bring the scooter to the place that serviced it for you and have them check the batteries to make sure that they pass a load test (do not try to drive the scooter they need to check the batteries with a full charge) If the batteries check out ok then you will have to have them check the charger and replace the charger if necessary. Hope this helps you
Mar 01, 2011 | Health & Beauty
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
My Schwinn S-180 scooter won't charge
Check your charger with a meter and see if it is putting out the correct voltage for your scooter battery. If it is, you probably need a battery, probably so anyway after 2 years. Good luck!
Mar 16, 2010 | Transport Schwinn Rechargeable Portable ...
We have charged the battery and when we turn on the scooter all it does it make a beeping sound and the scooter will not move
So the Battery charger is showing a green light (Fully Charged ?) Can you tell me the MAke and Model of the Scooter ?
Jun 12, 2009 | Pride Mobility Products Go-Go Elite...
On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Jan 25, 2009 | Razor E100 Electric Scooter
RTO 12v 70ah Leoch Battery For Scooter Or Wheelchair Logo
129 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
