Question about Boating
How to install a fire extinguisher on side of fiberglass center console compartment?
  • 2,926 Answers
Use a pencil to mark the holes for the extinguisher mounting bracket. After marking the holes,apply smal pieces of masking tape over the holes. This will prevent the Gel coat from chipping while drilling the holes for mounting the screws. If the side of the compartment is thick enough, you can use self taping screws. If there is access to the other side thru an access port, you can use machine screws and lock nuts to secure it. Keep in mind that you will want to use a 316 stainless steel fastener, and also apply a marine silicone in the holes before screwing the fasteners in place. 18-8 stainless will corrode/rust overtime, especially in a saltwater environment.
Posted on May 11, 2010
Testimonial: "This information was very helpful. Hate to pay someone to mount two screws. The masking tape was a very important step that I would have missed. Thanks a lot! "
  • Polo Joker
    Polo Joker Jul 24, 2017
    I used Gorilla Glue to mount a block of wood to the inside of my center console, then screwed the extinguisher bracket to the wood. This adds rigidity and prevents having to drill all the way through the fibreglass. The extinguisher has stayed in place for 20+ years on often-rough seas.
Name and explain at least 6 guidelines for placing of fire extinguishers.
Google is your friend in such cases. Read all the pages and make your own findings.
  • Emergency Standards ' Portable Fire Extinguishers ... https://www.osha.gov/SLTC/etools/evacuation/portable_placement.html Portable Fire Extinguishers Extinguisher Placement and Spacing. ... The following guidelines will help you identify the number and types of portable fire ...
  • A Health and Safety Guideline for Your Workplace Fire ... iapa.ca/pdf/FreeDownloads8_fireext.pdf · PDF file Fire Extinguishers © Industrial Accident Prevention Association, 2006. All rights reserved. 1 A Health and Safety Guideline for Your Workplace
  • Placement of Fire Extinguishers in the Workplace safeandcompliant.net/safe-kb/article.php?id=30 Placement of Fire Extinguishers in the Workplace. KB Home ... The following guidelines will help you identify the number ... Fire Extinguisher Size and Placement ...
  • Portable fire extinguishers. - 1910.157 - osha.gov https://osha.gov/pls/oshaweb/owadisp.show_document?p_id=9811&p... 1910.157(a)Scope and application. The requirements of this section apply to the placement, use, maintenance, and testing of portable fire extinguishers provided for ...
  • Guidelines to the Strategic Placement of Fire ... driftwoodontheocean.com/2016/04/11/guidelines-to-the-strategic... Fire Extinguisher Safety and Other Essential ... of placing the fire extinguishers in the ... to place your fire extinguisher, here are a few guidelines to ...
  • Geeks On Home: OSHA Fire Extinguisher Guidelines www.geeksonhome.com/...7717356_osha-fire-extinguisher-guidelines.html OSHA Fire Extinguisher Guidelines. ... The Occupational Safety and Health Administration maintains rules governing how fire extinguishers are used, ...
  • Fire Extinguisher Requirements and References in the ... amerex-fire.com/wp-content/uploads/2013/02/Fire-Extinguisher... · PDF file Fire Extinguisher Requirements ... there are additional requirements for placement, ... servicing and training with portable fire extinguishers beyond the ...
  • Fire Detection and Extinguishing Equipment Regulations laws-lois.justice.gc.ca/eng/regulations/C.R.C.,_c._1422 ... Fire Detection and Extinguishing Equipment Regulations ... Special Requirements; 7 ... Portable Fire Extinguishers; 90 ...
  • http://www.bing.com/search?q=guidelines+for+placement+of+fire+extinguishers&qs=n&form=QBRE&pq=guidelines+for+placement+of+fire+extinguishers&sc=0-46&sp=-1&sk=&cvid=405F1FDF23E64C4A8BD1FC6B5358AE64
    Jul 10, 2016 | Cars & Trucks
    How is fire extinguisher used
    Pull the safety catch, aim at the bottom of the fire (not the top of the flame), and compress the trigger.
    Jan 31, 2015 | Cars & Trucks
    What are the different types of fire extinguishers?
    there are 3 types:
    water
    carbon dioxide
    dry chemical
    to learn more about them go here: http://www.ehs.okstate.edu/modules/exting/Types.htm
    May 07, 2013 | Home
    Hi, I have a small Williams direct vent heater 14k btu that i want to install. for ideal placement, the double wall vent will be against the stud not centered. is this a problem? also can the existing...
    The vent pipe CAN NOT touch the wall stud. You can cut back the fiberglass insulation, but it must be a minimum of 6" away from the vent pipe on all sides.
    Jan 26, 2011 | Heating & Cooling
    How do i replace the fuse for the lighter in my '99 chevy lumina?
    Circuit Protection Underhood Electrical Center #1 Underhood electrical center #1 gm-06-00-703.gif
    Underhood Electrical Center #2 Underhood electrical center #2 gm-06-00-704.gif
    I didn't see the cig lighter mentioned in my online resource, but with my experience on GM vehicles, the under dash driver's side fuse box usually has a cig lighter fuse listed. If not, then you'll have to get a fuse tester and test each and every fuse until you find the burnt out one.
    If the fuse is not burnt out, there may be a broken wire behind the console.
    Console Removal & Installation Chevrolet Lumina & Monte Carlo To Remove:
    1. Disconnect the negative battery cable after first disabling the Theftlock® feature of the radio, if equipped.
    2. Remove the front floor console trim plate using the following procedure:
      • Remove the cigarette lighter.
      • Remove the transaxle shift handle.
      • Remove the front floor console trim plate by unsnapping from the console.
      • Detach the automatic transaxle control indicator socket and bulb from the trim plate and detach the electrical connector from the trim plate.
    3. Remove the CD storage bin at the front of the console by unsnapping it.
    4. Raise the console armrest and remove the compartment mat. Remove the screws from console.
    5. Detach the electrical connectors and remove the front floor console from the vehicle.
    To Install:
    1. Connect the electrical connectors and position the console on the floor.
    2. Install the screws and the compartment mat. Start with the front right console retaining screws and continue in a clockwise order.
      • Tighten the screws to 106 inch lbs. (12 Nm).
    3. Install the CD storage bin.
    4. Install the console trim plate.
    5. Connect the negative battery cable.
    Oct 17, 2010 | 1999 Chevrolet Lumina
    Need instructions on how to remove center console to access electric window switch.
    Here is what I could find, hope it helps.
    Good luck.
    Regards,
    REMOVAL & INSTALLATION
    See Figures 1 and 2
    The following procedure is a general procedure for console removal. You may have to modify or skip certain steps depending upon your vehicle.
    1. Disconnect the negative battery cable.
    2. Remove the shift knob, floor compartment door and console trim plate.
    3. Remove the instrument panel accessory trim plate.
    4. Unfasten the retaining bolts, detach the connector, then remove the console door.
    0900c152800900b7.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Remove the retainers, unplug the connector, then remove the console door
    1. Remove the seats, as outlined later in this section, in order to get to the lower rear screw(s) on the side trim panels.
    2. Remove the console side trim panels.
    3. If equipped, remove the switch pack housing with the switches.
    4. Remove the console compartment floor protector, bolt covers and bolts.
    5. Unfasten the screws mounting the console to the instrument panel and tunnel.
    6. Unclip the harness and accessory plug.
    7. Tag and detach all necessary electrical connectors.
    8. If necessary, remove any remaining retainers.
    9. Tilt the rear of the console up, then slide the front tab back out of the instrument panel and remove the console from the vehicle.
    0900c152800900b8.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Exploded view of a typical console mounting
    To install:
    1. Position the console in the vehicle by placing the front tab of the console into the instrument panel slot, making sure to align the screw holes.
    2. Attach the electrical connectors as tagged during removal.
    3. The remaining of installation is the reverse of the removal procedure. Tighten the console retaining screws to 89 inch lbs. (10 Nm).
    May 04, 2009 | 1986 Chevrolet Corvette
    Distance to keep between a 2000 watt heater & wall insulation?
    The fiberglass will not catch fire. There is a sfer barrier built into the wall heaters. When you install a wall heater you basically just cut the wall open and throw the unit in with the flue and gas and away you go. If you can to second guess take some of the insillation and take a match or a lighter and hold it in your hand and light the fiberglass, you will see that it wont burn even with direct flame on it. You are 100 percent safe
    Feb 12, 2009 | Dayton Electric Heater
    Boating Logo
    294 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
