Question about Duracell 1500W Power Inverter (D1500) 500-Watt Power Supply
Can i use my inverter when engine is running - Duracell 1500W Power Inverter (D1500) 500-Watt Power Supply
    Genius:
  • 1,027 Answers
Yes.
Posted on May 11, 2010
Connected a microwave (700 watt) and fault light turns on after few seconds on
engine has to be running with some high wattage items if your engine was running then your inverter is defective.
Mar 31, 2011 | RoadPro RPPI-2500W Inverter
I have a Yanmar 4.5 KVA Generator running into a Trace 2.5 KVA inverter/charger, the inverter requires 205-220volts to operate,once the inverter connects the voltage drops on the genny over a ten second+-...
try adjusting the gen voltage at no load to run at 240 volts
when the load comes on it will drop back to 220-235 volts
check the load output from the inverter as 2.5 kv is nearly 80% of the genset duty cycle
4.5 KV is start up KV and the duty KV is around 3..8 kv not the plated 4.5 kv
to get constant 4.5 kv you will need a 5.5-6 kv unit
if the current draw from the inverter is excessive , the engine may not have enough in reserve to over come the load and will not pick up the rpms
take the gen set and the inverter to a shop that has a calibrated load bank to test accurate power output to determine if the engine needs an overhaul
May 28, 2017 | Electrical Supplies
I have small portable generator with 220 vac in the philippines and a 12amp 12 v ac to dc converter. can i connect my 1000 w inverter to produce 120 vac becouse i dont have the batteries yet to run the...
no these are made to run off a batteries the 12 volt supplied from the gen is for charging batteries only and if the engine for starting the gen set has a battery their usual to small to run then their made for car style batterers.
hope this helps
Aug 14, 2010 | Vector 2000w Power Inverter
Trying to run a digital projector from a car battery
I looked at the power requirements of this projector, 280W, but that assumes a nice sine wave. Your inverted is supposed to put out 400W, but it's a modified sine wave. Under ideal conditions (including a good battery) this might be just enough. Connecting directly to the battery will help a little, because of the limited ability to get current to and through the cigarette lighter. Using a 100 foot extension cord will diminish the voltage a bit (less so if it's a heavy gage wire). I would try connecting the inverter directly to the battery, run the engine and skip the extension cord. If that works, turn off the engine. If that works, try the extension cord. If it won't work with the engine running, connected directly and no cord - there are two possibilities: (1) the projector just won't run on a modified sine wave, (2) you need a bigger inverter. --- regarding (1) I have seen lots of people having trouble with various devices. You might want to ask Epson support. --- Good luck!
May 26, 2010 | Black & Decker Black Decker 400 Watt...
I have a 2003 Dynasty and we're having an electrical problem that has just about puzzled everyone I've spoken with ! It all began over 2 years ago when I started the generator and the engine , to return...
Sounds to me like a problem arises when auxiliary batteries are getting charge from more than one source at a time. When unit is plugged in, or generator running, that supplies one source of charge to batteries, when you start the engine, that supplies another. perhaps it's sensing an overcharge condition when this happens, and is warning you that when you put too much charge at once to deep cycle batteries, you may boil them, and cause premature failure. Personally, if it were me, I'd disconnect the charge line from the alternator, and put it on a switch, that I could shut off, and on as needed, and be done with it. When generator running, shut it off. Double check operation of your battery isolator as well. If 2 strong sources start charging those batteries too fast, that's not good. I'd also think about, or discuss with an electronics guy about adding a diode to charge line from inverter/converter, to stop any possible feedback from alternator when engine running. That said, It shouldn't take more than 1/2 hr, to find charge line from alternator to batteries, and put a switch in a convenient spot in unit, to connect and disconnect as needed. Cheap and easy solution.
Jan 08, 2010 | Xantrex Technology 806-1800 Prosine...
Inverter beeps when I plug in extension cord. Nothing else
it is possible the alternator's power is higher than that of the inverter ,that is overload
Nov 17, 2009 | Coleman Cable Power Inverter PMP1200
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Tech Question
Automotive batteries are usually adequate for small inverters, (< 500 Watts). When used in a car, we suggest you run the vehicle of your engine occasionally while operating your inverter. If you use the inverter while the engine is off, you should start the engine regularly and let it run to charge the battery. Deep Cycle (marine) batteries are best for larger inverters as they are designed for several hundred charge/discharge cycles. (Automotive batteries wear out much more quickly after heavy discharge).
Aug 27, 2008 | Whistler Power Inverter
Duracell 1500W Power Inverter (D1500) 500-Watt Power Supply Logo
51 people viewed this question
Top Duracell Computers & Internet Experts
Rick Moore
Rick Moore
MrFixitSTTL
Bill Boyd
Are you a Duracell Computer and Internet Expert? Answer questions, earn points and help others
