Question about RCA HD52W59 HDTV Projection Television
Where would I buy the three brown fuses that are at the back left of my HD52W59 TV. I know one is not any good for sure - not sure about the others. The colors started separating a while ago - we can autoconverge when tv is first turned on and it does well for a while then it clicks and the red is out of alignment. Now the power button appears to come on but after about 30 seconds it goes back off - the tv picture never actually comes on. Was told it was probably the 3 brown fuses - have you had this problem before
  • RCA Master
  • 3,459 Answers
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Posted on May 11, 2010
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
It has curved screen and double letters
You have a defective deflection board. Normally there is a three brown fuses next to the fly-back transormer and one of then must me open for over current. You need to replace the fuse and resoldered all the Fly-back transformer pins...Good Luck
Aug 23, 2011 | RCA HD52W59 HDTV Projection Television
Our tv just had the three colors cross and picture became distorted, almost three dimensional. What could be the issue and is this an easy fix? The auto-convergence option is not showing up either on the...
Blowed Fuse on deflection board FL231. Deflection board is the bottom left hand side, and on the right handside of FBT flyback Transfomer is 3 Fuses in a Roll they will Look like Small brown rectrangler Caps But are Fuses it will be the Middle Fuse that is Bad.
Mats 1-800-628-1118
UED 1-800-648-6657
Jan 07, 2011 | RCA HD52W59 HDTV Projection Television
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | RCA HD52W59 HDTV Projection Television
Convergience not working, three color pictures and concaved top and bottom. Is there a module that I can replace?
Check the small brown fuse FL231 located just to the lower right of the flyback. There are 3 small brown fuses. The middle one is FL231. Most likely it is blown. The reason it blows is because of the lead free solder used on the new boards. If you turn the board over you will probably find cracked solder joints on the flyback terminals. Re-solder all of the flyback terminals and replace the fuse if it is blown. This fuse tells the TV that it is a rear frojection TV and not a standard CRT
Feb 08, 2010 | RCA HD52W59 HDTV Projection Television
My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call PartStore.com 1-866-925-7278
Dec 31, 2009 | RCA HD52W59 HDTV Projection Television
I have color misaligned in my RCA HD52W59 tv. I can see three different colors yellow, blue and red. It is intermittent issue. Please What is the best solution for that?
Go to menu then setup if you do not see convergence in the menu then you have a Blowed Fuse FL231 its on right side of FBT flyback transfomer will be 3 small brown looking caps But are fuses it will be the one in the Middle! Go to Partstore.com Look for FL231
Dec 03, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 APPEARS IN 3D, I DON'T KNOW WETHER TO REPLACE FUSES OR DO I NEED MORE TO FIX THE PROBLEM?????? PLEASE HELP ME!!! -MOTHER OF THREE
Hi, thank you for visit fix ya.
Common problem on this tv, Loose connections-and open fuse.
Re solder all connections around fly back, and replace a little fuse located beside fly back ( is a little brown box), you will See 3 fuses parallel beside fly back; replace fuse 400ma.
Thank you
Jul 28, 2009 | Televison & Video
Where do i find the fl231 fuse
its located just to the left of the flyback transformer. You will notice three small brown rectagles. The middle of the three is FL231
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
229 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
