Question about Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher
My dishwasher turns itself on even after I turn it off
It displays F1 and turns itself on even after I just turn it off. What could the problem be?
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
  • 784 Answers
SOURCE: Dishwasher "F1 and a small wrench symbol" blinks continuously
The unit has a leak causing floor sensor activated.
1- Unplug power cord.
2- Pull oull half way the drawer so an access from the bottom left could be obtained.
3- Use Paper towel or small towel to dry out the water on the bottom housing.
4- Wait for 48 hour so the sensor can be dry out.
Plug in the power cord. The unit will act as normal.
Your problem is solved.
However you can't operate since you know you have a leak problem. Let me know how it in progress and you decide to call service to fix it or I can guide you to fix it. Good luck.
Posted on Jul 05, 2009
garing
  • 998 Answers
SOURCE: Dishwasher turns on by it self. Gives F1 error
replace control board
Posted on Aug 08, 2009
  • 784 Answers
SOURCE: my dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Posted on Nov 01, 2009
  • 713 Answers
SOURCE: How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Posted on Jun 03, 2010
How do I stop the F1 error even after assessing there is no water in the bottom tray and dried it with hair dryer just in case
There should be F1 on both displays. "If power fails to the bottom tub it will cause the top tub to go F1. Test heater plate." (from the service manual).
If there is F1 on both displays it could be a faulty flood switch or PCB.
Jan 30, 2015 | Fisher and Paykel Dishwashers
I have just moved into a rental with a fisher and paykel nautilus dishwasher. I have turned it on at the switch and it keeps beeping with F1 displayed
F1 display means Flood has occurred. Call the company for more assistance. Here is a link- http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/521766I_DW920_ugm_NZw.pdf
Dec 08, 2012 | Dishwashers
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
F1 appears both drawers are flashing and beeping can't turn off power (it turns off for a moment and then turn itself back on with F1 code, beeping and flashing) Unplugged it hoping it would reset, it did...
F1 means that the flood sensor has been tripped. Remove the bottom draw and dry the water out. Mop the majority out and use a hair dryer to get it all nice and dry. This should clear the f1. There may be underlying issues of why the unit has leaked but see how you get on.
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Model DD603H - keeps coming on by itself and flashing F1 on screen? Need to unplug to turn it off? what do I need to do?
Not sure if this problem you are having is with both the drawers or just one of them.
F1 fault is linked to water level float switch being activated. But not sure why the unit turns on by itself. Take a clean cloth and wipe dirt around the door inside especially around the switches. The unit is very sensitive to contamination around the door edges. Good luck. Otherwise a technician on-site is your best bet.
Nov 05, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Cant turn off the dishwasher
Babas, the F1 fault code for most FP dishwasher models means that there is a leak. It can be one or both drawers. Regardless of which is leaking, your fault code is telling you that the base pan has water inside. You will probably need to call for factory service to repair.
Mar 31, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher Logo
188 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
