Question about Omega Paslode 901000 Impulse Cordless Finish Nailer
Paslode Impulse Framing Nailer won't operate
On my Paslode Impulse Framing Nailer, I put in a fresh battery and the light blinks green but the unit will not operate. It has a new gas cartridge and nails inserted, but the fan never comes on when I depress the tip and the tool won't fire a nail.
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
Paslode battery charger both lights blink at the same time
Sounds like you have a bad battery - the charger will do this if your battery is too hot or its defective
Jul 27, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse framing gun is dead, no green light
are you sure battery was charged ? if so , then battery contacts or circuit board may be broken.. but its probably a spark unit( little black box in handle of tool) that has gone bad. fairly easy to replace , but little expensive (60-80 dollars)
Sep 18, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode framing nail gun, bought a new battery, charged it (checked the voltage w/meter) put it in the gun and no green light... what do I check??? Bob
I would start with the battery contacts to make sure not corroded or bent, if no light still then you would have to take the handle halves apart and see if you have a loose connection at the curcuit board. Let me know and I will guide you thru how to do this.
Mar 01, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer was working fine then stopped working and there is no led light. i put another battery in but still no green light. Jim
check the battery contacts in the body of the tool for corrosion or bent or broke, also clean the battery contacts with an eraser
Sep 20, 2010 | RTO PasLode 900420 Impulse Framing Nailer
No action. fresh battery and gas paslode framing nailer
Check the small switch at the top by the fan . It has a small roller on it.This trips the switch for ignition. Lightly bend the arm in a small amout so that when the tool is compressed the switch will be activated
Jul 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Mar 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 900420 nailer green light cycles doesn't stop???
Sounds like you need a new circut assembly.
Around 40 bucks.
Thanks,
Jeff
Feb 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Omega Paslode 901000 Impulse Cordless Finish Nailer Logo
663 people viewed this question
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
