I can't remember the password on my Toshiba laptop!!! It's running Windows Server 2003, and for pete's sake i can not remember the admin password I setup for the laptop. I haven't used it for awhile, is there any free software to retrieve the password or bypass it. Please help me!
  • Willie Diaz
    Willie Diaz May 11, 2010
    mrdotcomguy,
    Thanks for your prompt response. I did go to safe mode, but it also asked me for the password, it would not allow me to boot up on safe mode unless i wrote the password. Is there another way?
  • Willie Diaz
    Willie Diaz May 13, 2010
    mrdotcomguy, thanks again for your answer, but my problem is I cannot log in Administrator because thats the password I forgot and unless I do so, the computer will not allow me to get to the command prompt to enter what you wrote above, the LOG ON TO WINDOWS appears, and unless I write the password required the logon message says THE SYSTEM COULD NOT LOG YOU ON.....the OS is Windows Server 2003 Enterprise Edition. I'm trying to access files that are very important, you have been very helpful and I'm grateful.
    Guru:
  • 109 Answers
Go to the safe mode :- Leave admin password empty if asked.
And then click on start-->run-->type cmd-->type control
userspasswords2 hit enter--> windows open's here --> on the top uncheck option for ask user name and password before entering windows. and then hit apply.
let me know if it works.
Posted on May 10, 2010
Testimonial: " mrdotcomguy, Thanks for your prompt response. I did go to safe mode, but it also asked me for the password, it would not allow me to boot up on safe mode unless i wrote the password. Is there another way?"
  • Try This...
    Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
    Use the arrow keys to select the Safe mode with a Command prompt option.
    If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
    Log on as an administrator or with an account that has administrator credentials.
    At the command prompt, type %systemroot%\system32\restore\rstrui.exe and then press ENTER.
    Follow the instructions that appear on the screen to restore your computer to a functional state.
    Good Luck!!!
  • Since its asking to you enter the password even in the Safemode, there isn't any option left but to go ahead and reformat the Operating System.
    You need to perform a PARALLEL INSTALLATION of a new OS in order to retrieve the Data. Make sure that you don't put same profile name that you have been using earlier on your laptop.
    After the successful parallel installation of a new OS, retrieve your personal data on a external hard drive and perform Clean installation wherein it will remove the original OS and the temporary OS which is gonna be installed.
Boot your PC using a Knoppix DVD. If you have access to another PC, download the Knoppix iso from Knoppix or other site that has it, burn to DVD, then try to boot with the DVD. You may have to go into the PC setup to set it to boot first from removable media. Boot order is important. Watch the boot screen for the prompt that tells the key to press to get into the setup. Once that boot from removable media, and the order, is set, then boot again with the Knoppix DVD in the DVD drive. Once in Knoppix, which usually has a very familiar-type graphical interface, you may find it simplest to use the built-in Samba server function,where you can set permissions of which other PCs IDs and passwords can access the PC via Samba. Samba server is accessed through one of options that you access from the bottom right. I also have used the opposite function of mapping another PC from the Knoppix. Using this, I was able to retrieve data files from a HDD which had a partition corrupted in such a way that no version of Windows would reinstall/upgrade. My backups were useless until I copied all my data off and repartitioned the HDD.. Of course, you have to have the Hard drive password, but you must have gotten past that since you got to the Windows signon.
Another option is to put the hard drive in an external hard drive USB-based enclosure and attach it via USB to another PC to read the data files. However, this may or may not work if the other PC is Windows based and the partition is corrupted as mine was. You could still boot the other PC with Knoppix DVD and see if it will read that external HDD, That depends on whether Knoppix has drivers to recognize that external HDD.
Posted on May 29, 2010
Testimonial: "Thanks so much for the advice, God Bless!!!"
How to do if locked out of Windows 8 laptop?
1. Run "lusrmgr.msc" to reset Dell Windows password.
In Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account password by just run the lusrmgr.msc. But you need to login your server or laptop with an account which has admin privileges. Note that resetting password with this tip might cause irreversible loss of information for the user account. This data loss will occur the next time the user logs off. You should use this command only if a user has forgotten his or her password and does not have a password reset disk.
Step 1. Start your PC and log on with an available user account which has admin privileges.
Step 2. Click "start" button, press "Win+R" to open "Run box". Type in "lusrmgr.msc" and hit Enter.
Step 3. Local Users and Computers appears, all user accounts of your computer will be list, right-click your user name and select "reset password".
Step 4. Type in a new password and type it again to confirm it, click OK.
After restarting you can login that user account with new password.
2. Remove Dell password by using a Windows password recovery tool.
This is a universal way to reset forgotten Windows password on HP Server or PC, no matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows Password Genius is designed to recover Windows password for any kinds of PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help reset server or laptop password Windows 8, but also Windows 7, Vista, XP and Windows 2000.
Step 1: Download and install Windows Password Genius Advanced on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk with CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your PC or Server and set the laptop to boot from the disk by changing devices boot order in BIOS SETUP.
Step 4: After boot from the password recovery disk, Windows password recovery tool will start automatically and display a friendly window. Then you can reset whichever account password of your PC or Server by a few clicks.
Windows Password Genius also allows user to create new admin account for your Dell Windows system without logging. With this new user, you can login your Dell computer directly and access control panel to reset other user password.
Jul 29, 2013 | Computers & Internet
Tip
How to Reset Toshiba Satellite Password
"How do I reset my admin password to my <b>Toshiba Satellite laptop</b>? How to bios password reset Toshiba Satellite? I want to <b>factory reset Toshiba Satellite</b>, etc." Large amount of questions on <b><a href="http://www.windowspasswordrecovery.net/">Toshiba Satellite password reset</a></b> can be shown at anywhere. What should we do if we have to <b>reset password Toshiba Satellite</b>? Now, it is time for us to discuss such problem now!<br /><br /> 1. Is there a <b>Toshiba Satellite </b><b>recovery disks</b>?<br />If the <b>Toshiba Satellite recovery</b><b> disc</b> is created before we lost password, it will be helpful for us to solve the problem. The operation steps can be referred to <b><a href="http://windowspasswordrecovery.net/article/toshiba-password-reset.html">Toshiba Satellite password removal</a></b>.<br /><br /> 2. Are there still other accounts with administrative privileges?<br />Especially, we may always ignore the default or built-in administrator account which will save the day, such as in Toshiba Satellite XP, Vista. While, <b>Toshiba Satellite Win 7</b> has not default account password. Take Toshiba Satellite Windows 7 account with administrator rights as example: <br /> Step 1. Login Toshiba Satellite PC from the available admin account.<br /> Step 2. Start - Local Users and Groups - lusrmgr.msc (input in the Search box) - ENTER - Local Users and Groups - choose Users.<br /> Step 3. Right click the account needed to reset password, and then select Set Password.<br /> Step 4. Input and confirm the new password.<br /><br /> 3. <b>Toshiba Satellite Password Recovery</b> with free tool - Ophcrack <br />Ophcrack cracks passwords no longer than 14 characters using only alphanumeric characters. We can download its ISO image file online and then burn the file into a CD/DVD. <br /><br /> 4. DIY a <b>Toshiba Satellite </b><b>password</b><b> re</b><b>covery disk</b><br />If we are still in trouble of password cracker, we can easily get out of problem by DIY a password reset disk with professional Windows password recovery tools. There are many Windows password breakers or removals. Just take one of the most proven effective tools - Ainorsoft Windows Password Recovery as example:<br /> Step 1. Download <b><a href="http://windowspasswordrecovery.net/download.html">Windows Password Recovery</a></b> and burn .iso file to a bootable CD/DVD/USB Flash Drive via an accessible PC.<br /> Step 2. Boot the locked computer from CD/DVD/USB.<br /> Step 3. Unlock lost Toshiba Satellite password with the burned CD/DVD/USB.<br /><br /> Easy for us to break or recover forgotten Toshiba Satellite password now! The above four methods can make sure that we instantly <b>reset password Toshiba Satellite</b> laptops or notebooks for Windows 7, XP, Vista, Server 2008, 2003, etc. <br /><br /> <i>Source</i>: http://windowspasswordrecovery.net/article/toshiba-satellite-password-reset.html<br />
on May 18, 2011 | Toshiba Satellite L500 Series Notebook
How do i reset the cmos password on Toshiba Satellite T135DS1325RD
Maybe you can use Smartkey Password Recovery Bundle to help you, and you can see the detail dirction from http://www.recoverlostpassword.com/products/passwordrecovery.html
Jul 02, 2012 | Toshiba Satellite T135DS1325RD Q12 ...
Change local admin password from ADall my members are in domain i want to change all my memmber local admin password from server 2003 which i have it
for this you can use a spcial tool called intelliadmin network administrator in that you have the feature to change local passwords of all clients
Mar 24, 2010 | Microsoft Windows Server 2003 Enterprise...
Forgot password
Hi Laurence,
Try going to safe mode by tapping F8 on startup.
login with the admin account. By default the password is blank so you should be able to login.
Now go to control panel > user accounts > select your account and click change password or delete password.
else create a new profile.
If you are unable to login with the admin as well then you you
that should fix it..
Anup
Apr 06, 2009 | Computers & Internet
How to change the password?
Hi there
If you don't know the admin password then your pretty much stuffed unless you can get hold of a boot cd which will allow you to hack the password and change it so you gain access to the admin account. there is such software but its highly illegal
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
I forgot my Administrator Password
While you lost windows os password, you can enter safe mode (F8 when booting up) to remove windows password when you lost user account password, but when you forgot admin passwords, there is no way to change it, you have to use tool to recover administrator password. Yesterday evening, I forgot my Windows administrator password. At last, I used Windows Password Seeker to retrieve my Windows password successfully. It's worth a try.
http://www.passwordseeker.com
May 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
325 people viewed this question
David Payne
David Payne
