Seal Turntable - lousy recording!
It sounds awful - it appears that the arm is too light and keeps jumping - it isn't the record - it plays fine on my normal turntable - what do I do?
  • 189 Answers
HELLO
These cheaply-made turntables only do ONE job and that is to archive your record collection. Not surprised by the fact the record plays great on your normal turntable.
The arms on these turntables have quite a heavy tracking weight to them and you cannot adjust it. My advice to you is if you want to archive vinyl there are plenty of quality HIFI turntables out there that will blow away your Seal turntable. Don't be tempted to put a small coin on the headshell as this will INCREASE the weight and probably damage your record.
A friend of mine has one these awful Seal tables and I think they are pretty bad sound quality, also they go under many different brand names.
AVOID!
Posted on May 12, 2010
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
My need on my turntable jumps around on my records
If it keeps sliding in one direction, it probably needs an anti-skating adjustment or to be put on a level surface. If it jumps all over, the stylus weight is probably too light or the surface it's on isn't stable enough.
Sep 24, 2012 | Sony Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
I have a sony PS-LX33 turntable. When I try to play the record, the needle gets stuck in one position and will not move across the record. I have fitted a new stylus but still does not work. Can you help...
First check that you can move the arm right across the turntable platter. Do this without a record to avoid scratching it. If you can take it to the middle at the same height as a record then no mechanical fault is present.
That being OK it perhaps means that too much weight is being applied to the stylus. You can adjust it with the weight at the end of the arm. It should have numbers on, try it on 1 or 2 to start with - playing a record. The idea being to get the pressure just right without making it jump out of the groove or too heavy giving a rumble sound. It's a question of trial and error.
Sep 07, 2011 | Sony Audio Players & Recorders
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
106 people viewed this question
 Grubhead
Grubhead
