Question about Frigidaire Affinity ATF7000ES Front Load Washer
I have an E 21 code. - Frigidaire Affinity ATF7000ES Front Load Washer
    President:
  • 1,382 Answers
Hi, Check for a trap in the hose that comes from the tub to the drain pump and frigidaire says it must be reinstalled. Try to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel. In side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible( put down some towels as water always stays there). Then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . If the impeller are stripped you will have to replace the pump.
Thank you!
Posted on May 11, 2010
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
Oct 06, 2014 | Washing Machines
I have a 1997 Dodge Stratus with Check engine codes as follows: Key ON,OFF,ON,OFF,ON codes 12, 34, 21, 55 I understand 12 is recent disconnected battery & 55 is end of test, but can't find definition of...
Jeff: Go to "Allpar dot com" website and look for a complete list of codes for the older Chryslers. From mine I remember code 34 as having at least two posible meanings: a) EGR Solenoid circuit problema, and b) Speed control problema. Code 21 means a problema in the Oxygen sensor. Amclaussen.
Aug 23, 2013 | 1997 Dodge Stratus
What is fault code 21 on a 1992 toyota xtra cab?
Generally speaking code 21 for Toyota is a problem with the O2 sensor circuit. It could be the sensor or the wiring back to the computer.
Oct 02, 2012 | 1992 Toyota Pickup
95 dodge caravan se code 12 21 55
Well, the code 12 is telling you the battery or the computer has been disconnected in the last 50 starts, code 21 is a problem with the O2 sensor, and code 55 is telling you there are no more trouble codes stored in memory.
Code 21 means the O2 sensor is not switching from rich to lean, which can be a faulty sensor or a fuel problem.
Aug 28, 2012 | Dodge Caravan Cars & Trucks
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
Error code 21
There are 3 step to repair 21 error
If you got 21 error then there is a 94% chance that your computer has registry problems. To repair 21 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 21 error.
Jun 09, 2009 | Yahoo Mail
New codes
telepest codes 29TH NOVEMBER 2008
00=98 B0 BA 52 D3 21 08 B4
01=D2 EA 29 B7 B5 52 E9 AD
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Telewest codes 21/11/08
anyone got todays codes 21/11/08....cheers
Nov 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Engine diagnostic codes
I don't have a dodge ram but the codes for the dodge vehicles where pretty much the same. For my intrepid the codes read for the following numbers
12 - Problem with battery connection (This usually happens if you disconnect the battery)
21 - Problem with the oxygen sensor circuit
52 - Oxygen Sensor signal input indicates rich mixture during engine operation.
It sounds like you may need to change an oxygen sensor. Hope this helps.
Aug 15, 2008 | 1995 Dodge Intrepid
Washing Machines Logo
266 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
