Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Which one' i check the bios but w/c one there?
  • 33 Answers
Well it depends on your BIOS type but it usually resides at advance setup. Look for any USB titles and enable them.
Posted on Mar 30, 2008
How to check the bios password on an acer aspire 5534 without going into bios?
thake it apart and pull out the battery on the mainboard /clear bios to reset bios password to no pasword, you can even de-dust it while doing this, just refer to youtube disasembly video - there is one for almost anything, other than that you can maybe do the same by flashing the bios, but i don't know if you can ever read/retreve the actual password, much easier to just remove it then to read it :)
Apr 29, 2014 | Acer Aspire 5534-5950 Notebook
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
Helo, i have updated the bios on asus p532n-e sli premium, and after instalation the sistem won't turn on.pls this is urgent. a nice day
According to your problem first check the bios update. Check that you have updated the bios properly. Run the motherboard in updated bios, so reset the bios. This may occur for another cause also. So check the electric outlet where the system is being plugged. Make sure that the SMPS is OK and compatible with motherboard. If the SMPS fulfil the minimum requirement of the pre updated motherboard then updated bios may not support. Check that you have installed the SMPS power cable in your motherboard properly. It will help you.
Jun 06, 2011 | ASUS P5N32-SLI Premium Motherboard
Bad bios checksum
The BIOS sum check has detected faulty BIOS information. This can occur when the BIOS battery is nearly flat.
Replace the BIOS battery and then go into the BIOS configuration and set the Date and Time etc.
Mar 12, 2011 | ASUS Eee PC 2G Surf Notebook
Drive A media error bios checksum error
your current bios is corrupted since the check-sum that was generated when your bios eprom was flashed with your current bios version doesn't match the check-sum that is generated as now, meaning that your bios changed for a few bits. you can fix this problem by re-flashing your bios with a good ROM file that you can download from your computer maker site or your motherboard bios maker site, also upgrading your bios with a newer version will take care of the issue as well.
Mar 07, 2011 | Computers & Internet
Screen display is not stable.screen flickers
CHECK IN BIOS. If the screen is flickering in BIOS then it is hardare issue.
1.Please power ON the notebook, Keep tapping F10 as soon as you power it ON.
2.Press the F9 key to reset the BIOS defaults, it will ask to restore defaults. Hit Yes.
3.Press F10 and save the changes.
In BIOS please check if you can see the flickering. If the screen is same in BIOS then it is hardware issue. If you do not see the screen flickering in the BIOS then please update the BIOS and graphics driver
Feb 09, 2010 | HP Computers & Internet
Brightness not working . tried pressing fn and left control.
Turn on laptop keep tapping on F2. Check if you can go to the BIOS if yes then check the BIOS version from your laptop. Check the website if BIOS is out dated download and flash the new BIOS. If your cannot access BIOS, there might be something wrong with some keys on your keyboard, same thing update BIOS. if all fails replace keyboard.
Sep 21, 2009 | Computers & Internet
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Jan 23, 2009 | Intel Motherboard
Bios check sum error
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
55 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
