I start up my pc tower this all appears to work as i can here it boot thru the speakers but my flat screen dosnt come on. the power light flashes on and off but no image. ive changed power leads and connecter cable but to no avail.the problem started when my girlfirends screen did the same thing i swapped her monitor for mine but it didnt work i put my monitor back on my pc it worked the first time i booted up but once turned off anf on again the problem started.
  • 4 Answers
Since you swapped monitors for testing. check the video card and reseat it , if still not working reset bios pulling the battery out while unplugged . good luck
contact me for further steps
Posted on May 11, 2010
I was updating drivers thru Device Manager & it D/L a Lenovo system driver; wouldn't boot; removed CMOS battery & got in; deleted wrong driver & now won't boot
did you try restarting and hitting F8 immediately to screen that gives option to start using last known good configuration.
May 02, 2016 | Lenovo Computers & Internet
My Toshiba Tecra M5 won't boot. The power light flashes on and off, the fan starts but nothing is on the screen. How can I get it to boot?
Well, it sounds like you have a hardware problem. Start by removing the Ram and hard Drive from the machine and insert a boot disk. If your not getting the Tecra Splash screen when you press the power button, the screen that appears before the windows boot screen, you may have a bad Monitor or Burned background lamp or faulty BIOS install or upgrade. Any of which will give you this problem.
Dec 26, 2010 | Toshiba Tecra M5-S4332 Notebook Pc
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Wont boot up
try removing all cables connected to your tower, (including power cable, mouse, keyboard, VGA cable, scanner, printer, camera etc.)- then press the power button for at least 5 seconds, this is what we call POWER DRAIN, then try booting up your system again, if still unresolved, power off your tower, then open up your chassis, reseat the cables of your HARD DISK -- try again. if still unsolved, try entering the BIOS, check if the HARD DISK is detected..
Sep 07, 2009 | Compaq Evo N610C Notebook
Hi, when i boot the system nothing appear on the system. i initially checked my ram it was not workinhg so i bought a new one but still the system won't start up!! it is a p4, intel d865, 512 ddr ram ,...
If you doesn't hear any beeps, at least you must hear one beep.
Clear CMOS or remove the Lithium Battery CR2032 in the motherboard about 1 minute, to know which MB is hang up with processor, then put it back again & power it on.
Aug 17, 2009 | Personal COMPUTER - LENOVO THINKCENTRE A61...
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Open Questions:
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
