Question about Sylvania SRT2319 TV
Audio This is the second time this has happened. When turning on the TV there is no audio. Then, after turning the set off (this time, overnight) the audio mysteriously returns. I think I have tried about everything (no, it's not the mute button) butcan't figure this one out. I know, it's not an expensive TV and I was going to dump it and get another but I will keep it as long as it works. Can you shed some light/sound on this??? Thank You. John
  • 346 Answers
Check or replace the speaker(s)
Posted on Nov 10, 2008
TV was working fine earlier today. Now, when the TV is turned on, audio and video will be fine for the first 30 seconds, then everything goes black and audio cuts out. When this happens, a faint buzzi
this works for me.....hold down the off button on top of the tv for at least 5 seconds....(not the remote).....then try the remote on button
if it does not work the first time....try holding down the tv off button a bit longer
Jan 02, 2015 | Panasonic PT-56DLX76 Television
There is something on some channels that is describing verbally what is happening on screen and we can't find out how to turn it off
Just look at the remote and find a button that is labeled MTS, SAP or Audio. Press this button one time and a display on your TV will show you the audio that your set is tuned to, (i.e., English or Spanish). If it shows AUDIO 2 or Spanish, press the button again until it displays AUDIO 1 or English then press ENTER or OK. With that, the audio should be correct.
Read more:
Sep 09, 2013 | Televison & Video
I can get a picture , but no sound on the TV . What am I doing wrong?
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a 19 inch Vizio HDTV hooked up to cable. It has worked beautifully until two days ago when 3 stations all of a sudden began speaking in Spanish and 3-4 stations (different) audio went mute. This all...
In the audio menu there is a setting for "SAP". This stands for Second Audio Program. Some stations will broadcast a SAP signal along with the normal signal. Some don't, That is why some stations don't have any audio. Turn that SAP off.
Oct 14, 2009 | Televison & Video
VIZEO LCD turns off or picture pulses
I can't say that this is the problem, but the behavior is that of a failing solder joint in the power supply; these tend to be intermittant and random. Most semiconductors just flat die under the right conditions but it is possible for a power semi to fail internally exhibiting just the same behavior. Since both audio & video are down together, I would check the main power supply first.
Yours may be separate from the lower level electronics and user replaceable. You won't hurt anything if you pull the AC plug overnight, remove the back panel and look inside to see if you have a separate board with larger components on it; cylindrical ones (capacitors) and largish blocks (transformers & chokes). If you find this, check for a part number or have the set's model number handy and call the mfr.s service to ask about repair or replacement costs. You can ask them too, if my diagnosis sounds right to them.
May 05, 2009 | Vizio VO47L 47 in. LCD TV
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Background voice, 27 inch "truflat" 2005 model
What you're hearing is the descriptive audio track included on many DVDs for vision-impaired viewers. Does this happen when you're watching regular TV or just with DVDs? If it happens with regular TV, do you have a cable box?
Regular broadcasting sometimes uses SAP (second audio program) to send additional audio, and this descriptive audio may be the SAP channel on some programs. Check your TV's audio settings to make sure you don't have SAP turned on. There may also be settings for SAP in your cable box as well, so check there too.
When playing a DVD, descriptive audio is usually an alternate audio track. Check your DVD player setting to make sure you've selected normal audio for playback.
Apr 04, 2009 | RCA TruFlat 27F520T 27" TV
Left a dvd movie in player overnight - now have no audio.
Did you double check the connections from the DVD player to the TV? Maybe something happened to the connection overnight. If that dosen't seem to be the issue then the only other thing I can think of is that the Audio Encoding chip inside the player must have gone bad. The problem now is that it would cost more to repair the audio encoding chip then replace the whole player.
Sorry I couldn't help any further.
Thanks for reading!
May 01, 2008 | Cyberhome CH-DVD 300 DVD Player
Sylvania SRT2319 TV Logo
48 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
