Question about Philips FWC555 CD Shelf System
CD player will not initiate or open unless you unplug ang then plug back in
FMW37 cd drawer will not open
quite likely you need to take it to a repair shop . OR buy a new one
May 22, 2015 | Audio Players & Recorders
I have a panasonic dvd/cd player (model NVVP31EBEBL) and i can't remove the dvd disc! any ideas, please?
You mean the disc is stuck inside the player? if that is the case try first turning off the player then turn it bck on and see if you can take teh disc out.
If not you may need to open the player to take the disc out because this can be a mechanical problem or the disc is broken or something..
Hope that helps.........
Aug 05, 2008 | Televison & Video
My jvc player rejects my cds when I put them in. what do I do?
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Dec 02, 2010 | JVC KD-S640 CD Player
It says off and thats all
CD stuck in player.
Unplug.
Remove lid, small black screws on side and along the top of the back.
Fiddle with latch on left side near front that controls the door.
Once latch is released, open door and remove all CD's.
Make sure 2 CD's are not **** in player.
Move CD cage carefully. It should run smoothly along. If not it is locked in 'switched off mode' or CD is stuck half in and half out. If CD stuck fish CD out carefully.
Plug back in without any CD's in.
System should run back and forward and then lock at left hand end.
Put lid on and try one CD in one slot.
Dec 27, 2009 | Technics SL-MC6 CD Player
Carriage jam
hi,
Just open the printer and u will find in right hand side one black colour unit is there it moves two and fro and insite it there is a gear it is connected through other mechanism gear in left hand side after opening it u will definately find that its hinge is broken or gera is broken.
replace it ang ur problem will resolve,
bye
wasim
Jul 30, 2009 | HP PSC 1610 All-In-One InkJet Printer
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
Installing cd players
YOU HAVE THE ILLUMINATION WIRE HOOKED INTO THE RADIO
Oct 02, 2008 | 1999 Chevrolet Tahoe
Sony compact disc player initializing
Have you tried pressing hte RESET switch?? It's behind the removeable front of the stereo, use a biro or something and hold it in for a bit.
Failing that, check that there isn't a CD already in it, could be a dodgy CD?
Dec 26, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
CD Tray on one side doesn't open.
I have also had the sticking CD Tray problem with my Stanton. I disconnected the until and unplugged the separate read out control panel. I was going to strip it down, but when I plugged the power supply on it worked fine again!!!!. I wwill reconnect and see what happens!!
Dec 14, 2007 | Stanton C.501 Dual MP3 CD Player
Philips FWC555 CD Shelf System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
