Mits WT42413. No power on. Before the green light would come on. Any ideas? Thanks
  • 2 more comments
  • tnasah May 11, 2010
    I have done that step. I get pwr to the board. What next?
    Thank you. Tried the procedure and I got a 1,2 sequence. What could be the issue since this sequence means no error?
  • tnasah May 13, 2010
    No sign of Glycol. I do have the schematic so I guess I will just go the old fashion way before I part it out. The tubes look pristine.
    Thanks. I am very versed in circuit trouble shooting. I will give this a crack and let you know. spiscean on y!
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find as I am familiar with this set.
SD TECH
Posted on May 11, 2010
  • SD Tech
    SD Tech May 12, 2010
    unplug the set and try it again---with "no error" it means something outside of the shutdown is wrong and someone would have to have a schematic and start tracing voltages from the power supply to various other parts of the set.
    I would also suggest you take a good look for any signs of Glycol having leaked out.
  • SD Tech
    SD Tech May 13, 2010
    There are some logical things to do here. This set has a light box and you can remove it intact and use the Mitsubishi remote to turn it one etc.
    If you do not know how to do this I can tell you.
    With it out I would try to confirm if certain voltages in the power supply come up and then instantly go down--shutdown will kill them almost instantly.
    The large board on the right (viewed from the back) is the power supply and High voltage board. I have seen a few of these with a shorted cap near the HV output transistor. Be aware the set uses two different grounds--when measuring in the power supply you have to be on the correct one to get correct readings.
    With the light box out you can tilt it and lay it face down so all the boards face the back towards you. I would begin by taking a very good look for any cracked or bad solder connections at plugs or certain parts on the boards. Next you begin by getting a meter in position and using the remote turn the set on(remote receiver is on tiny board at top by the middle lens).
    Let me know and do not give up as in truth it could be a minor part bad and the hard part is to find it.
    Look for voltages that do not come up at all etc. If no error detected something is open... A open will be harder to find as it does not create an error code. A shorted part etc will leave a error code or create one.
    Let me know and know I am willing to help as much as possible.
    I have been on this site for close to two years with nearly 2,000 problems solved with a 97% approval rating.
    I have from time to time bent the rules to help people, I have a Yahoo IM and if you provide one we can talk while you attempt to find the problem. I am in California and here from about 5 - 9 every evening.
    SD TECH
  • 6,993 Answers
once any electronics refuses to turn on, such situation is known to be a power problem. In order to solve such problem, those things that are associated to powering the electronic device needs to be checked, starting from the power outlet to the components on the power panel.
First, you need to check if power is entering into the TV, after that, check the power board of the TV. There you will find, capacitors, fuses, transformer, etc.. If any of these power components are bad, there is no way the TV will turn on.
Therefore you need to diagnose the power board of the TV, test its components with meter to detect if any of the components are bad. After the diagnoses, you will discover what went wrong and you can proffer a solution by replacing the bad component.
You need to have a technical ability before you can do what I suggested above. Also, before you attempt opening the TV, allow it to cool, because TV stores current.
Good luck.
Posted on May 10, 2010
Green timer light justs blinks and the tv will not come on
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-52725 Projection TV. I
Call MITS, and try to get a tech to assist. Green timer flashing is "waiting for CPU to boot". Normally 70 seconds after plug-in. If doesn't stop, then not booting, and you won't be able to turn on. It only boots after being unplugged.
Apr 22, 2010 | Televison & Video
50 in mits tv wont power on. green reset light
Hi, It's either the lamp or the power supply capasitors. Thanks.
Sep 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blink green light of death - mits ws55613
Just click below for the solution desame as your problem;
http://www.fixya.com/support/t1012464-fixed_blinking_light_but_still_no
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mits. TV Green light blinking issue.
Just click below for information related to your problem;
Regards;
VOTIT
Jan 20, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Misubishi WS-65613 Flashing green reset light
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
My WD-52825 wont turn on and its not the lamp....
If you want to have it repaired email me at ima_rm2000@yahoo.com i have repaired over 200 of these sets. I have been a professional electronics technician for over 40 years. email me for details and pricing. beter prices then mits or pts
Nov 05, 2008 | Televison & Video
57" Mitsubishi won't power on, blinks green timer light
It is a common failure of the 57" Mits. DLP. The problem is a defective thermistor and is covered by Mits. Contact a local repair shop and they will fix it free (parts & labor)
Sep 04, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mits 65" wont power on
set could have a short and be in shut-down mode ...making just a blinking green light on the front.
remember your standby circuit is always on waiting for a remote command and can be damaged by surges in the line from storms.
please add a surge protector in future after you found the failure.
May 11, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
