Question about Jenn-Air JCD2389G Side by Side Refrigerator
Water coming out of the bottom of the jenn air refrigerator
  • 11,800 Answers
Possible causes:
1 - when the fridge defrosts the water is supposed to exit thru a hole at the back and bottom of the rear inside panel to a tube and from there to a drain tube and evaporator plate at the back. That hole is clogged, unblock it.
2 - a leak from your incoming water line hooks to the water valves or the water cooler.
Posted on May 10, 2010
I have a Jenn-Air side by side refrigerator. It has built up ice in the very bottom about three inches thick. What could be the problem?
ice is water freezing so check where the water is getting in ( leaking water bottles being frozen, bad door seals, too frequent door opening etc
Jul 10, 2016 | Jenn-Air Refrigerators
Water constantly drips from the dispenser and also water leaks at the left side bottom of the refrigerator
replace the filter and inlet valve of water.because of that only water is coming continously
Jun 11, 2010 | Jenn-Air JFC2087HRS Side by Side...
JFC2087HRP Jenn-Air freezer creaking noise.
Most of the time this happen when the refrigerator has been hooked up to the water, and than you unhooked it!!, the water that is in the hose makes that sound when it's pushed by the air in the hose. that's a typical problem when you unhooked the water.
May 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
Jenn air jcd2389ges has a sporadic water leak. I suspect that it is occurring during defrost. A clogged line? How do I access this to clean out?
Your plastic lines at the bottom left side of frig have dry rotted from the heat of the compressor. it will leak every time the water comes on to fill the internal tank. I had the same problem and I replaced mine with copper.
Oct 29, 2009 | Jenn-Air JCD2389G Side by Side...
Water leak @ bottom of jenn air JBL2086HES
It could be condensation, but be sure that all of the connections are tight.
Jun 28, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Ice and water hook up for Jenn-air JSD2789GEB
The water coupling is usually located at the bottom rear of the Fridge and will require an installation kit (easily obtained at your local Home Improvement Store) and tapping into an existing copper cold water pipe (the kit will/should includes the line tap).
Apr 26, 2008 | Jenn-Air JSD2789GEB Side by Side...
Water/ice maker not working and freezer/frig not cooling evenly(top warm/bottom cool)
the relay valve that controls the water is stuck.
likely hard water deposits,
Feb 03, 2008 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
155 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
