Question about InFocus LP640 Multimedia Projector
Projector is not turning on...and turns off when on
My projector is starting to act crazy. I have to hit the on button atleast 20 times to get it to turn on. While it is on, it will turn off automatically. Sometimes the projector acts like it is getting no power and wont turn on or make the beeping sound that tells you it is turning on.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
If the lamp is good, it could be a fan not working, which would be a bad fan or bad main board. IF the fans are working, then I would have to say that the power supply was bad or the fan laying flat against the bottom in the right rear corner is bad.
Posted on May 11, 2010
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
My PDJ6553w projector turns on, giving me 2 min picture, turns off and the fans goes crazy
sony lcd turns on, giving me signal and picture in 2 minutes, then suddenly turns off and the fans goes crazy. what can I do to prevent this? I have tried to reset the projector and switched the powermode to normal, but this didn't help.
Feb 16, 2013 | Viewsonic Corporation Viewsonic PJD6553w...
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
Feb 23, 2011 | HP G60-120US Laptop
I need to reset my lamp counter on my projector pt-lc56e but i dont know how please help me
After changing the lamp you should be able to turn on the projector and it should run for approx. 10 minutes, allowing enough time to reset the lamp counter. Hit "Menu", select "Option 2", hit enter, which will bring up "Lamp Runtime", press and hold enter button approx. 3 seconds. The selection will change to "Time Reset (Power Off)". Turn off the power and it will reset.
Jan 26, 2011 | Panasonic PT-LB10VU Multimedia Projector
Will not turn on
if you did not hit the power button it would not of broken it
Oct 03, 2009 | Sharp XR-10S DLP Projector
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Dell 1800mp will not turn on
I have a DELL 1800MP projector & when I try to turn it on the light blinks for a while then turns off??? Any idea of how to fix this??
May 31, 2009 | Dell 1800MP Projector
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Wont start up
Pls clean the filters and check the lamp by opening the lamp cover. If lamp looks okay in all aspects then send the projector to any engineer to check the ballast unit of the lamp.
Viren
+919814903739
Nov 26, 2007 | Dell 1100MP Multimedia Projector
InFocus LP640 Multimedia Projector Logo
258 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
