Question about Janome Memory Craft 4800QD
I have a Janome MemoryCraft 4900. My question IS - can I oil my machine? I can not imagine why the needle bar , bobbin area and any other moving metal parts for that matter -- would not require a drop of sewing machine oil from time to time. The manual does not mention oiling anything. I have owned my machine for about 2 years. I know it was a lot quieter when I first go it.
  • 92 Answers
All moving parts needs oil or it will wear out and that is where the noise come from. wcbotha@yahoo.com
Posted on May 12, 2010
  • Karlen319 Mar 18, 2011
    BUT, you did not say how to oil the machine, so what she asked is how to oil her machine, so you did not help in any way.
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
Needles lock
Have you hit a hoop while sewing? Is the needle jammed up and will not come down or down and will not go up? You need to make sure that you have no thread in the bobbin area. Even a tiny little piece will lock it up. Have you kept it oiled ? There are several places that need oiling. Bobbin area and needle bars are the two main ones. Make sure your needles are all the way up
sometimes the screws will vibrate loose on the needle bar .
May 02, 2015 | Janome MB4 Four Needle Embroidery Machine
I have a Janome Memory Craft 4900. I broke a needle while sewing in a zipper. I replaced the needle,but now the machine makes a medal scraping noise when I sew. I took off the needle plate and bobbin...
did you find the tip of the needle? Also you may have a nick in the metal where the needle hit and broke.It can catch on other parts and need to be sanded or replaced.One time I had this issue and I found the tiny broken tip under my bobbin case.
Jan 18, 2014 | Janome Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
I have a janome 9700 designs work great letters are not coming out neat
have you tried changing the needle?
rethread the machine top & bobbin
Apr 26, 2012 | Janome Memorycraft 9700 Computerized...
My Janome sewing machine 4900 is showing error E1 how do I fix it.
try these suggestions
change the needle--normally flat side goes to the back of the machine
make sure the bobbin is wound correctly & that the bobbin is inserted
correctly in to the bobbin case
also make sure that the bobbin spindle is in the position to the left when not in use
clean under the needle plate & in the bobbin area for lint or loose threads
if none of these suggestions work then the machine needs to be checked
Apr 10, 2012 | Sewing Machines
Janome memory craft 6500 sewing machine...all of a sudden, the bobbin thread does not attach itself to the needle thread...i have taken off the plate, cleaned out the dust, rethreaded both top and bottom...
Has the bobbin case dislodged and moved? there should be two red marks one on the bobbin case and one on the outer holder, are they lining up? Sometimes as these cases are held by a magnet, they will get dislodged and move slightly, especially in a jam up.
Take out the bobbin case and clean under it, then replace it matching up the red marks.
If the bobbin case has actaully been struck by the needle during a dislodgement, it may well pierce the bobbin case plastic, look for burring or marks on the outer flange area. If this has occured, the thread may catch on the burr as it comes over the bobbin and jam again.
You can buy a new bobbin case if yours is damaged or maybe just file the burring with an emery board (remove it from the machine first of course).
Lastly, check your needle hasn't been bent, burred, or put in backwards, any of these can prevent a stitch from forming.
If all the above fails, then it is possible that the timing has been knocked out and you will need to get it serviced by a technician.
Oct 16, 2011 | Janome Memorycraft 6500P Computerized...
What type of bobbin should I use in my Memorycraft 4000.. Plastic or metal..I have been using metal, is this ok?
You should be using plastic bobbins for the MC4000, see: http://content.janome.com/index.cfm/Machines/Accessories/All/Bobbin_-_Plastic . Usually the machine comes with a handful of the correct size and type bobbins. Using the wrong bobbin could result in the needle hitting the bobbin and damage may occur. (Broken needles are the most likely possibility; damage to the bobbin case or timing could occur and would require the machine be serviced.)
When you buy more bobbins, make sure that they are labeled for Janome or a machine that takes the same size bobbin. See this site for a list of machines that also take this size bobbin: http://www.sewingmachinesplus.com/102261103%20-20pk.php
I hope this helps.
Mar 01, 2011 | Janome Memory Craft 4000 Sewing Machine
Sewing Machines Logo
271 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
