Question about Troy Bilt Tb70ss Gas Trimmer
My troy gas trimmer is difficult to start. Now it won't start at all at the 2nd use of this year. It's used for only one season. Any hint is appreciated. Tony.
    Problem Solver:
  • 9 Answers
O I SEE THANKS FOR USING FIXYA
Posted on May 10, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
My troy built starts but will not speed up enough to use even after it warms up. It is 2 years old but only has 3-4 hours of use on it . Can you help me?
Is it 2 cycle or 4 cycle? Meaning, does it take plain gas, or mixed gas?
Clean the plug, clean the carb with either choke cleaner (4 cycle) or wd-40 (2 cycle) by spraying it into the choke hole after you take off the air filter.
You may also want to spray some of the choke cleaner or wd-40 into the gas tank with the gas to help clean out the whole fuel system.
Only use choke cleaner for 4-cycle regular gas units. For mixed gas, use wd-40 in place of choke cleaner.
Try to start it and then go back and forth from half choke to full choke until it starts picking up.
Jul 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Trimmer will not start after winter how can I repair it.
Get rid of all that crappy fuel from last season and give your carb a good cleaning and then start from square one.
Apr 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Craftsman 34cc 4 cycle weedwacker will not start
Start by removing and cleaning the spark plug. The check out the screen at the exhaust port and make sure that it is completely free of carbon build-up. I never run my equipment out of gas at the end of a season, I usually add some fuel stabilizer to the gas and run some into the carb before shutting down for the season. Hope this helps and good luck.
Jul 10, 2009 | Craftsman 25cc Gas Line Trimmer
Having a hard time to fill the bag and almost not cutting grass
Well it could be your blade on the mower, over the years i have had to profect my blade sharpening skills.
sometimes when a blade is shapened its not done correctly causeing a lack in the blade tossing the grass properly and more or less turning into mulch on the lawn.
You should have your blades on a push mower if used once a week through out the season sharpened once a season then
if you have large amounts of rocks, sticks and pinecombs then 2x a year
if you only use it here and there then ushally ever 2 years is good.
another issue could be the engine bogging down when going over heavy or wet grass. this is no fun..
what I do with my lawn mower is clean the bottom and spray it with PAM cooking spray has been far the best solution, spraying the bottom of the deck and blade.
Now saying that if you try this method then remember no wet grass so dont over water your lawn.
some people like to use POR 15 on the under side of their mowers as well but I havent tryed this yet but hear it works great.
so there is ways to prevent slow and no discharge into the grass catcher.
hope this helps but yes I would say clean the underside of your mower and have you blade sharpened by a professional. dosent cost much and so much more worth it.
Aug 14, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy Bilt Tb70ss Gas Trimmer Logo
253 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
