Question about Pyle PLDVD135 Car DVD Player
Lost detachable jack and wat to know how to power it up
Well i think i freid my amp i had a friend take a look at it and thats wat he said might of happened cuz as soon as i try to put a fuse in it blows it so idk wat to do now i want to get it fixed but in...
  • Open the Amp up. Look for any black spots on the board. If it "blew" you should see a burnt electrical component, perhaps a RCA jack where the cords go. That's the first step in looking at a suspected "blown amp"... is to try and see if you can see what blew.
  • Let me know what you find. If the fuse is blowing just as quick as the power feed is connected there is a burnt part of the board and/or a component. I suspect a diode. They allow current one way and are what one may say a fuse on the board itself in the form of a component.
  • Let me know.
Tony
May 30, 2011 | AudioBahn A2300HCT Car Audio Amplifier
My gateway laptop wont charge at all i even bought a new battery and charger for it but it still wont charge or power on at all. if anybody knows wat is wrong please let me know.
This can be caused by either your motherboard or a broken power jack. Most common is the broken power jack. These can be replaced some will be separate from the motherboard and plug into it while others are soldiered to the motherboard and will require adept soldering skills so as to not over heat the circuits near the power jack. Most parts will be available on Ebay or online laptop parts stores including the power jack and if needed the motherboard.
Feb 19, 2011 | Computers & Internet
Battery is showing 100 percent but you unplug power supply computer shut down also when you wiggle cord power shuts down
The DC jack in the computer has detached itself from the motherboard causing intermittent shutdowns, the laptop must be dis-assembled to re-solder the jack back in place, and may need to replace the DC jack if the old one is not suitable.
Feb 08, 2011 | Toshiba Satellite A105 Notebook
How do you change the paper size on a canon ir3025 photocopier from A4R to A4
Open the drawer,detach the blue paperstop by pushing it left and downwards.Insert the stop again at the A4R holes.Unlock the top and front vertical lock and slide it to the A4R possition.Set the blue dail to A4R so that the machine knows wat tipe of paper is loaded.
Aug 17, 2009 | Office Equipment & Supplies
Have no manual. Need to know how to clean it,
Since it was saturated with blueberries, pears and yogurt, the house began to smell, so I put it outside in a wheel barrel. In the morning it was covered in ants and the juicer now resides at the West Sonoma County Disposal.. Problem solved.....
Apr 12, 2009 | Jack Lalanne Power Juicer 250 Watts
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Pupl guard
yes tri star products search it on google.com
Jul 20, 2008 | Jack Lalanne Power Juicer 250 Watts
Pyle PLDVD135 Car DVD Player Logo
51 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
