Question about Sony Computers & Internet
All of a sudden my sony clie would not power up when I pressed the power. I have replaced the battery, but to no avail. answer?
  • kimajatie May 10, 2010
    When I do as you say, unit comes on briefly, flashes hold, the with green power button still on, screen goes dark again.
    My Sony Clie all of sudden would not turn on even after I replaced. I tried holding down power button while hitting reset butto, but his only turned unit on temporarily, than it flashed hold and turned off quickly. Answer?
    President:
  • 2,923 Answers
Here's what you need to do:
Plug it into the cradle, make sure the green light on the cradle is on.
With it still in the cradle, hold down the power button, then press the reset button on the back while still holding down power button.
Initialization screen comes up, memory is cleared, do a sync to restore memory.
If that did not help, you may need to contact the manufacturer and have them repair it.
Thank you and good luck!
Posted on May 10, 2010
    Guru:
  • 1,049 Answers
You will have to restore your data afterwords.
  • 1 more comment
  • NA NA
    NA NA May 10, 2010
    It sounds as if your battery may be going bad, the Clie consumes more power running than it charges on boot and if the battery is completely drained it will fade out even if plugged in USB. If the battery is still able to hold a charge, leaving it charging for several hours before trying to sync may help. If the battery is completely gone, there are no replaceable batteries for the Clie and there will not be many options but to replace it.
  • NA NA
    NA NA May 10, 2010
    You can try and update the battery yourself, but this is a safety announcement put out by Sony that discourages it. Most likely this is because the device uses a Lithium ion battery. There are options available though if you want to try yourself.
  • NA NA
    NA NA May 10, 2010
    This PDF has instructions on dismantling the Clie and replacing the batteries. (With screenshots)
Little adapter that plugs into both sony clie sj22 and power cord is broken. How do I get another one?
Same thing happened to me. If you search Amazon for SJ22 sync cable, you should find some. I ordered $9.95 five-foot cable from Amazon (via Boxwave)--it says In Stock, but then they said it is no longer available, and I had to buy $15 version with retractable very thin cable--hope it lasts.
Downside is that computer needs to be on to charge device.
If you want to pay $30, the original package appears to be available at:
http://www.amazon.com/Sony-PEGA-AC10-AC-Adapter/dp/B00005Y3Y2/ref=pd_cp_e_0
Jan 12, 2011 | Sony CLIE PEG-SJ22 Handheld
I need driver for my ux50 . i dont have the cd.
Hello. you can go to this link to get a free downloadable driver. http://www.css.ap.sony.com/clie/general/homeCategory.asp?HmCat=CLIE%20Handheld
Regards, Joe
ps - kindly rate my answer as helpful. thank you.
Feb 15, 2010 | Sony CLIE PEG-UX50 Handheld
How do I CLEAR everything on my Clie
Hard Reset CLIE Sony Series
  1. Connect the CLIE handheld using the AC adapter and take out the stylus pin by twisting the upper part of the stylus.
  2. Push down and hold the power button of the unit and use the stylus to slowly press and release the reset button on the back.
  3. When the Palm screen will appear release the power button.
  4. At the “Erase all data?” prompt, push the upper part of the scroll button on the front of the device to confirm OK. The Sony pda is now reset and you have only to follow the SetUp steps as prompted.
Feb 01, 2009 | Sony CLIE PEG-SJ22 Handheld
Change out a battery in a t665c clie
It was like looking for a needle in a haystack but by doing a search on the internet I finnally found site that had info on how to change out the battery for my modle of clie.
Nov 16, 2008 | Sony CLIE PEG-T665C Handheld
Sony Clie PEG-NX70V/U
I believe that the battery door is located next to the hold button. you need to use a cross screw driver to access and pull the battery. i havent try it, but i am going to acquire a battery to replace mine.
May 12, 2008 | Sony CLIE PEG-NX70V Handheld
Clie PEG-SJ22 does not charge battery
Have you tried resetting the unit? There's a little button on the back that you can press in with a paper clip. That'll cause the unit to reset (you won't lose data) and then you might be good for charging.
Dec 16, 2007 | Sony CLIE PEG-SJ22 Handheld
Not starting up I get nothing!
Press the power button and hit the up button to reset to start.
I have the same issue and my palm battery will not charge and stil working on it. Try line 1 first
2nd option remove the battery and try without it. Then put the battery back in.
Hope this helps
Aug 07, 2006 | Sony CLIE PEG-SJ22 Handheld
Broken lcd of sony clie nx70v (where can i buy one?)
I have no freakin idea! I searched ebay and found only one for $200 !! I bought mine for $60, just needed a replacement battery.
If anyone finds out were I can buy one for under $60 please tell me!
Mattx2@gmail.com
please don't email me any questions, Im way to stupid to answer.
Jul 30, 2006 | Sony CLIE PEG-NX70V Handheld
Computers & Internet Logo
501 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
