Question about Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010
It will not start, it is filled with gas/oil, i just replaced the spark plug and i cleaned the filter
    Problem Solver:
  • 9 Answers
O I SEE THANKS FOR USING FIXYA
Posted on May 10, 2010
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
Didn't winterize my Husquarna 21 hp Kohler riding lawnmower last year.
Dave, grab some gun out or any old carburetor cleaner... remove spark plug, spray a few squirts into the hole then reinstall the plug. Now go to the carburetor, spray some into it as well....
Try starting it , if it starts and runs for a matter of seconds then your carburetor needs to be serviced...and THAT you can do yourself...trust me. If you need help on how to do it, I will send you a link for a you tube video.
Oct 09, 2015 | Husqvarna Garden
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Poured in the wrong oil/gas ratio into my Craftsman leaf blower. Stupidly poured entire 2-cycle oil provided directly into the blower reservoir and filled balanced with gas (Should've read instructions...
it only means your spark plug is covered in oil. I do not expect any damage. try and remove and clean spark plug maybe use some gas to wash the excess off. maybe put a small drop of gas into the spark plug hole and replace. this may help start the engine. what you need to do this flush out all the oil so that the correct mix can get in. Also ensure no oil has got into the air filter ensure that is clearn before trying to start it again.
I hope this was useful
Oct 31, 2013 | Echo Inc. 25.4 CC Backpack Blower
Problems & Solutions for Mountfield 725m
Remove clean or replace spark plug. Remove clean or replace air filter. Ensure oil is full. 30w. Drain gas tank fill with fresh gas with Stabile. Gas over 30 days old no good! Try to start. No start clean or replace carb.
Jul 12, 2013 | Garden
I have a 8h.p.Tecumseh tvm195 it doesn't want to
Replace spark plug. Replace air filter. Fill oil. 30w. When plug is removed pull rope several times to blow out cylinder. With air filter removed spray starter fluid into air intake hole of air filter, try to start.
Ensure fresh gas only is in gas tank. Always add Stabil to gas. If no start clean carb or replace. carb.
Jul 10, 2013 | Garden
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Oct 12, 2010 | Briggs & Stratton Garden
My 660 raptor quad is making like a humming/deep whistling sound when I try to start and won't start. It has good spark and new fuel. I noticed that the oil tank has built up pressure as I opened it the...
Sounds like the carb has over flowed and filled the crankcase with gas.
You will need to drain the oil, and re-fill it with new oil at the proper amount. Also replace the oil filter.
Clean the air filter and replace the spark plug.
Clean the carb, making sure the float and float needle are functioning properly.
That should fix you up!
RSRBOB
Jul 16, 2009 | 2001 Yamaha XTZ 660
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Logo
129 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
