Question about Ricoh Aficio 450 Copier
Ricoh 2045 Is it possible to scan documents and have them save to a folder on the network - instead of having them sent as large e-mail attachments?
  • 87 Answers
Yes.
Go to your desktop. Create a folder named "scans" on the desktop, and share it. Give the "everyone" group full access, or give users permission to modify files. Depending in how its set up.
On the copier, since you already have Email setup, your dns servers will be entered. Go to:
user tools, system settings, admin tools, address book management. Either select a user, or new program. Fill in user name ect. Select folder. It will ask for a path. Enter the path using the following template"
\\computername\scans. You should be able to test it out. If it is successful, then it will prompt you to login. This is your local login for the computer with the scans folder, The password is its password. Press ok to save.
Select scanner, scan document to the user that you set up. If the memory goes from 100%, to 99%, to 100% quickly, it worked.
You can use variations of this on a server too. If its a domain server, assigned to a group, the user name and password are what the user uses to access the active directory.
Posted on Mar 28, 2008
How to clear scan data
Your machine will show 100% and that is correct. It doesn't mean memory full, but rather the amount of memory that is still available. Once you scan a document you will see the memory drop down to 99% or even lower depending on the size of the scan. If you don't see this happening than you are not scanning. Other than that your scan will either go to a folder on your PC or straight to your email. All you need to do is locate the folder it saves your scan in (usually created in your C: drive) or check your email folders including your Spam/Junk mail folders.
May 25, 2016 | Ricoh Office Equipment & Supplies
How to scan and send document
Place your document face down on the scanner bed. Press the button that starts the scanning process depending on your scanner or printer.
Save the scanned file to your computer by clicking "File" in the menu bar at the top of the screen, then choose "Save as." Choose the folder in which you wish to save the document from the drop-down menu in the window that popped up during the saving process. Choose a name for the document, then click "Save."
Sign on to your email account, then choose "New" or "Compose" to start a new email message. Click on "Attachments" or "Attach." Wait for a new window to pop up, then choose the file you scanned from the folder where you saved the document.
Wait a few seconds for the file to attach, compose your email message, then click "Send." Your scanned document will now be sent to the recipient's email address.
Aug 22, 2013 | Office Equipment & Supplies
Bothers MCF-490CW 4 in 1 || scanner - when scanning multiple pages, what must I do so when I send as an attachment the attachment is one group instead of each individual sheet?
Create a WORD document then paste each images on a page, save the Word document and then send this Word document as an attachment in your e-mail.
If you do net want to send the Word document then you can create a PDF of the Word document and send the PDF file as an attachment.
Jun 06, 2011 | Office Equipment & Supplies
How to scan documents to an email address
you should first right click on yoru destop and find "NEW" click on "make new folder", then type a name for the folder (anything you want). Now go to your scanner software and find the preferences and tell it to save scanned documents to your NEW folder. another option is to simply scan a document and when its done, click "file, save as" and save it to your new folder. When you are done scanning, open your email program and type in the email address to where you want to send the documents. when you are done typing the "subject" and a short note to whomever the mail is too, go to "insert" or "attachments" (varies depending on you email program). find the folder with your documents in it and hold down the "Cntrl"key and then click each file you wish to include. then click "ok" and all the files should now be attached to your email. BE AWARE, there may be a limit to how much data you can include in your email. If your email provider rejects your message due to file size being too large, simply send the files one at a time in multiple emails. There are also options out there (too numerous to list) that will allown you to send large files that are too big for your email program. I hope I haven't confused you. Good luck
Mar 23, 2011 | Gestetner DSc232 Copier
What is the defrance between aficho 450 & 2045
the aficio 2045 is new version of the aficio 450.
so on the 2045 if you have installed printer/scanner option you can scan directly to folder on your computer or you can scan and sent documents to email addresses ,also the print or copy is much more quality.
you have a touch screen control panel.
mainly the look is the same with some new design on the look, but also some staff which has bean detected as problem on the aficio 350 now are corrected and improved.
Dec 13, 2009 | Ricoh Aficio 450 Copier
Scanning a document and attach it to my email
Just scan the file, use save as, choose file type,name and then location to save file, to (folder) you created in My Documents ,ie; Temp (folder).Later when sending e-mail attach file to message by clicking attachments browses to My Documents, Temp click file then attach file.It is now attached to your message.If you can save as PDF file do it ,it will be easier for person receiving.Good Luck.
Sep 09, 2009 | HP DeskJet F380 All-In-One Printer
Send scanned document too the computer
For this issue that you are having. You need to have the printer connected to your network. You need to have the manual for the printer setup. Once it is connected to your network. You will be assigning an IP address for the printer. You need to add it on your printer list using its ip address. Once connected, try to go to the printer itself. Look at the menu and look for the scan folder. The scan folder must contain the ip address of the computer you are sending the copy to and also the exact location of the folder it will be saved. Onced setup, all you have to do is to press the scan button then it will automatically save it to your preferred computer folder. Please be also noted about the file formats that your scanner will create. Usually, people uses jpg,jpeg but i recommend .Tiff cause it won't loose the quality of the scanned picture or document
Sep 05, 2009 | HP J4680 Office Jet All-In-One Printer
Merging attachments of scanned files sent by email
You can use the IP Scanner software to scan the documents from your Bizhub to your pc. Once the documents are in your PC you can take apart which pages you want from the scanned documents and save them to another file and e-mail them through your computer that way.
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Ricoh Aficio 450 Copier Logo
684 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
