Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I want to transfer saved files from my Maxtor PS 3200 to my computer. How do I do this as when I plug it into my USB port, it doesn't see it.
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
IF your harddrive is showing in my computer then you can copy and paste for data transfer.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 10, 2010
Maxtor basics 500GB external hard drive not working
Every time you turn your computer on it is going to "spin up" and the light is going to come on. Just because the light goes out and it idles so that you can't hear it anymore doesn't mean it isn't still on. It is. You can verify this by using windows explorer to view it and its files.
Jun 29, 2012 | Maxtor BASICS Personal Storage 3200...
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
I can not see my usb maxtor 3200 hard drive in my
this could idicate a low power supply for the device. some computer do have front usb ports, the truth about this front port is that they lack the power to supply some of this devices (being 200GB). If you are connecting it to the front usb then try using the main one behind the pc.
also note that usb polling which acts by reducing power consumed by the device may also be a cause(that is if you are using a modified version of windows other than that from microsoft since the modifier can alter that as well). Also try using it on a friends pc to see the outcome.
do let me know of the out come.
good luck
Jul 04, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
When i plug the usb port to my maxtor 3200 external hard drive into my computer, it says my computer does not recognize my usb or it has malfunctioned what should i do?
go to device manager/USB Root Hub/right click/properties/Power Management/uncheck the box that says "Turn of this device to save power"
Dec 06, 2009 | Computers & Internet
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Transfering data from Maxtor to a new computer
It's a USB Hard drive, so you should plug the USB port into one computer, put your information on it, then plug the USB port into the other computer. Browse the Hard Drive for your data. It's like a larger flash drive.
Feb 10, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
I will tell you how to solve it, but this will void your warranty!
I had the same problem. What i was intended to open the box take the HD and use it as an internal HD.
When I opened the box I saw the HD jumpers were set on Cable Select I picked the jumper and plugged it to Master. Plugged it back to AC power and USB. It works. I donno why but it just worked.
Good Luck!
Nov 21, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
67 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
