Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Wd 500gb not showing
How do you Assign an unused letter manually using Disk Management
  • 106 Answers
UNDER **** MANAGEMENT, RIGHT CLICK ON THE DRIVE FOR WHICH U WANT TO CHANGE THE LETTER...THEN CLICK ON THE CHANGE DRIVE LETTER & PATH....WHEN THE NEXT WINDOW POPS UP CLICK ON ADD...AND ALLOT THE NEW LETTER OF UR CHOICE :-)
Posted on Apr 05, 2008
Dead hd wd caviar 80 gb
Is the "dead" hard drive 80GB? or 500GB?
I presume you set up this hard drive as the second hard drive, or as an external drive. You can do these:
1. Disk Management (check the readablility):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. Is this hard drive info exist in this screen? If it is, then the hard drive is not dead.
Click on the hard drive info, right click, and you can do some actions (format, expand the volume, assign a drive letter, etc.)
2. If necessary, test and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Feb 20, 2014 | Western Digital WD Caviar Green WD5000AADS...
The file on my Seagate FreeAgent Pro 880 gig , wont restore to new formated drive ............ letter have change when reinstaling Windows Xp. I see all the different partition on the Seagate. But the...
The Disk Management snap-in is an administrative tool for managing hard disks and the volumes or partitions that they contain. Use the Disk Management snap-in when you want to add, to change, or to remove drive letters on drives, on partitions, or on volumes on your computer's hard disks, CD-ROM drives, and other removable media devices.
Your computer can use up to 26 drive letters, from A through Z. Use drive letters C through Z for hard disk drives. Drive letters A and B are reserved for floppy disk drives. However, if your computer does not have a floppy disk drive, you can assign these letters to removable drives.
Before you modify drive-letter assignments, note the following items:
  • Changing the drive letter of the system volume or the boot volume is not a built-in feature of the Disk Management snap-in.
  • Many MS-DOS-based and Microsoft Windows-based programs refer to specific drive letters for environmental or other variables. If you modify the drive letter, these programs may not function correctly.
How to assign a drive letterTo assign a drive letter to a drive, a partition, or a volume, follow these steps:
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
    Note If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then clickDisk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
The drive letter is assigned to the drive, to the partition, or to the volume that you specified, and then that drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool. Thanks or using FixYa! John
Feb 21, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
When I connect the hard drive, the computer makes the sound indicating that it has been connected, and I can see it under the connected devices in the control panel, but it doesn't show up under My...
One problem could be that the drive is trying for a drive letter that is already taken by the system.
1.) Click Start->Setting's->Control Panel->Administrative tools.
2.) Computer Management
3.)In the management tool under Storage->Disk Management.
4.) Can you see your drive in the list?
5.) If already formatted and data present and you can see your drive right click on the drive and click on change drive letter and assign a new drive letter to it.
7.) If showing unused you will have to format it.
8.) Now after you change the drive letter it should appear in Explorer.
Hope this helped.
Jan 26, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cannot access hard drive, USB port detects it, but does not access
You can verify what drive has been detected by your Operating System, which I assume is Windows of some sort by going to: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk will be displayed with all existing partitions.
I order to use any partitions in your new drive, you will need to assign a drive letter to each new partition.
If you have a brand new drive that is completely unformatted, then you will need, also via the context menu, Create partitions, Format partitions and assign a drive letter so that you can use the formatted partitions.
Hope it helps: let me know how you go!
Below is example of Disk Management display showing my external USB 300GB drive with _EXT disks & displayed context menu:
Jan 02, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Can't locate my jump drive - where is it?
Check your disk management, it may not have had a drive letter assigned.
right click my computer, go to manage, choose disk management
right click on the drive there and choose assign a drive letter. Change the letter to an unused drive letter and it will show up.
Jun 25, 2009 | HP Compaq dc7100 PC Desktop
My slave hard disk is not showing in my computer
Is it formatted ? Does it have a drive letter associated to it? If not then either format it (right click on My computer -> click Manage -> click Disk Management. Now right click the drive if it is showing there and either create partitions and/or format it if it not already formatted.
If it's already formatted, and you just need to assign a drive letter, then in Disk Management, right click the drive and click Change Drive Letter and Paths and assign an unused drive letter, say Z.
Close Computer Management and open My Computer. The new drive should show up now.
HTH,
Deboo
Jan 05, 2009 | Seagate 250GB Maxtor DiamondMax Plus 21...
Not geting my f: removable storage on my pc acer aspire 57207
What's your Operating system?
If it's WinXP...does the drive show up in "Disk Management"?
To get to "Disk Manaegment" applet in Control Panel, do the following:
From your desktop (icon screen), Right-click on the "My Computer" icon and select "Manage"
Next, click on "Disk Management"
Is your drive showing up here?
If it is there, is it being assigned a drive letter?
Is the drive letter already in use?
If it is...then all you need to do is assign this particular drive a new (unused) drive letter and it it will then be displayed in "My Computer" as a valid drive.
May 12, 2008 | Computers & Internet
Not showing my external hard drive
I HAVE SOLVED THE PROBLEM! or at least this works for my my book 1tb external hard drive. when i initially connect it i get the 'new device detected' pop up thing, but then it doesn't show on my computer. However, I have found that keeping the device pllugged into the computer but removing then replacing the power source from the device causes it to show up. That's all I did, unplug the power cord on the back and replace it. The computer says 'new hardware detected' and 'found my book mass storage device,' then it appears on my my computer tab. Hope this works with you as well!
Dec 04, 2007 | Western Digital My Book Essential Edition...
External Drive not recognized
Have you tried in Disk Management Right-Clicking on the drive and selecting 'Change Drive Letter and Paths...' ? That is the normal way to change or add a drive letter to any drive, internally or externally attached (other than by network connection)?
Dec 03, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
628 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
