Question about HP Color LaserJet 2600n Printer
I have a HP 2600 color printer that I would like to print only with the black ink. Can I remove the empty colored cartridges and override their settings for the black print only?
  • 231 Answers
No.
The Color cartridges must stay in the machine or it will not feed the paper through.
It is a colour printer, and will always need cartridges. Even if set up for mono printing, there mat still be a tiny amount of colour toner added to the page. (Model dependant)
Posted on May 11, 2010
My color ink jet is empty--I have put a new black cartridge in, and want to print only in black but cannot override the printer saying the color one is empty--I need to print stuff for work-how do I do...
with that printer you have to have both cartridges in the printer if you have the old color cartridges put it in and see if that works but more the likely you are gonna have to buy a new color cartridge
Mar 16, 2011 | Dell P703w Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Apr 27, 2010 | HP Color LaserJet 2600n Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
May 31, 2009 | HP DeskJet 932c InkJet Printer
Can't print without black Ink
From HP's website:
The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges.
Try this::
Leave the empty cartidge in and go to print, select the printer, click on preferences, then the paper/Quality tab. there select color and best. This way you wil be able to print your document.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2008 | HP Photosmart C6280 Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Mar 20, 2008 | HP PSC 1510 All-In-One InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP Color LaserJet 2600n Printer Logo
234 people viewed this question
Seeker5211
Seeker5211
