Question about Cub Cadet Lawn Mower Blade Drive Belt CUB CADET 75404077 CUB CADET 95404077
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
LT1042....LESS THAN 22 HRS....PULL OUT PTO AND NOTHING HAPPENS...HELP PLEASE
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
Posted on Sep 15, 2010
Cub Cadet 1042 are junk. Your clutch is most likely broke. A typical problem. Also, is the belt intact? Also, they mow like ****.Sorry you bought one, so am I.
Posted on May 31, 2010
    Problem Solver:
  • 9 Answers
O I SEE THANKS FOR USING FIXYA
Posted on May 10, 2010
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
I have a cub cadet rzt50 2006model, when I pull the PTO switch to engage the PTO nothing happens
check to see if you have voltage to pto if do bad pto replace it if not check the fuse then the switch
Aug 26, 2014 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Belt. came off... pulling up blade engagement knob nothing seems to happen.....I have trackter up on blocks with blade cutting height at 1 with engine runnig the blade engagement knob switch ...
sounds like a bad PTO, that is the electrical gizmo on the bottom of the engine's driveshaft which engages the bottom pulley, running the deck. you might luck out and find the fuse is blown so follow the wire from the PTO back until you find the fat part in the wire. the fat part is an in line fuse holder with a fuse in it. if the fuse is bad and blows again, you need a new PTO
Aug 19, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
When I pull up on the PTO lever the blades don't
You have a belt adjustment problem, or a broken belt. Look at the area where the belts are, you will probably see problem immediately. Good Luck
Jun 12, 2011 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
My PTO switch does nothing - blades do not engage - how do I fix? I pull up the switch and nothing happens. Model is YTH2448T serial # is 279200, I think it is a 2006 model. Help - please.
With test light check for power at the switch and at the plug of the pto. There might also be a fuse blown. You can always check the pto by jumping power from the battery to the pto with engine off and you can hear it click and see it move to verify that pto is not the problem.
Mar 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Cub Cadet Lawn Mower Blade Drive Belt CUB CADET 75404077 CUB CADET 95404077 Logo
4,241 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
