Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Usb still dont work or appear in device manager
Hey i found the Cd but which driver should i install is it the chipset? but when i tried to install it this one appeared "dll function call crash ISRT.calldllfn" and the wizard was interrupted before via setup program could be completely installed.the system has not been modified. i also tried the site but it has the same result. pls help
    President:
  • 2,351 Answers
Hi noel06, I have read all your post. In order for you to install your chipset drivers use your CD to first uninstall the the drivers. If you do not your system will crash & burn.
(You were lucky on your first try).
(DO NOT RESTART YOUR PC AFTER UNINSTALLING).
When the CD finishes uninstalling you can than re-install the chipset drivers. Go to Foxconn and download your chipset drivers.
http://www.foxconnchannel.com/EN-US/support/downloads.aspx
Fill in the three windows as:
Motherboard
Socket 462 A
K7S741MG-6L
Click the Search button.
As you will see many Foxconn boards use the same drivers.
As long as your board is within the list (which it is), download Foxconn's drivers (check the date of these files to your CD files.
The web site list newer drivers.
Good luck! Take your time....
Mike
Posted on Apr 02, 2008
2 Suggested Answers
peping
  • 99 Answers
SOURCE: usb still dont work
you have reinstall your os ,there is alredy a corrupted or missing files in your system,but before do that, you have first to change the Bios setup of the usb controller ,make it enable.then restart your pc.
I think, i am having a usb port malfunction. i just formatted my lg-ibm xnote lm50a with xp3 and installed all the drivers but all my usb ports don't function. it does not detect printers and mouse...
Have tried installing the CHIPSET Driver for the Motherboard?
Check the device manager for any bang on the devices meaning either a driver is missing or a wrong or incorrect driver is possibly installed, unless a REX "x" is foung beside USB hub then that would mean that is it busted or damaged.
but it is unlikely to have a USB hub/port to be busted unless physically, install the chipset driver and check again make sure you restart the system after installing the CHIPSET driver to make sure that it is properly installed in Windows and that it will detect the USB ports in device manager.
Oct 30, 2011 | LG X-Note LM50 Notebook
Usb not detect in my pc
Try to uninstall the usb device from the device manager.
To open device manager right click on my computer or computer icon then click on manage..there you will see device manager..right click on all tge usb device one by one and then click on unistall..restart the computer and then check you can also install the drivers for the chipset of mother board with tge drivers cd which you have...if nothing is workimg contact the mamufacturer of your computer there might be some kind of hardware issue
Oct 14, 2011 | HP ScanJet 2400 Flatbed Scanner
System did't found audio driver
my sound is not installed and i no have suporrt sound drive
Feb 01, 2009 | Altinex DRIVER/GLI CARD, 2-IN 2-OUT,...
USB Hardware Installation Problem
Try the following:
To fix the Error 13: Data is invalid problem, go to Start, Run... and type "REGEDT32.EXE" without the quotes to run the Registry Editor. Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ENUM\PCI and you will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04".
Under each of these folders will be another folder with a long numerical name.
Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install.
HIGHLIGHT THE ENTRY "VEN_xxxx" for that device and select 'SECURITY'-'PERMISSIONS' FROM THE WINDOW TOP MENU and then tick "Allow" for "Full Control".
Close REGEDT32 and then continue with the installation of your device.
This wil lremove the Error 13: Data is invalid from your wnidows 2000 / 2K / XP system. Repeat this for each hardware device you get the Error 13: Data is invalid problem with.
Jan 14, 2009 | Dell Inspiron 6400 Notebook
The usb ports and the pci slots do not work
Yes, this can still be fix, try first to run the setup CD for your ECS motherboard to reinstall the driver for those devices...if still not fix you may need to download the latest driver for your motherboard from ECS web site and update the driver for those devices..
Oct 14, 2008 | EliteGroup ECS 755-A2 Motherboard
No sound device
? mark means no sound driver install or errors in Device Manager. u can check ur mother board cd room or can search ur audio driver in web or below may be ur answer
Question: Where do I locate motherboard sound drivers?
Answer: Users who have motherboards with on-board audio (often with VIA, Realtek, or C-Media chipsets) may have issues with their audio or AC'97 errors in Device Manager. Often this is caused because the operating system has been reinstalled and the motherboard chipset drivers are not installed. To resolve this issue try following the below steps.
Let Windows redetect drivers
If you have not recently reinstalled Microsoft Windows it's possible that your audio drivers are simply corrupt. Open Device Manager and remove all devices under "Sound, video and game controllers" and any "Other devices". Once removed reboot the computer and let Microsoft Windows re-detect the audio drivers.
Motherboard chipset drivers
Reinstalling the motherboard chipset drivers will usually resolve this issue. If your computer came with a Motherboard CD, install the chipset drivers from the CD and the sound drivers if also available on the CD.
If you do not have a motherboard CD, obtain the motherboard chipset drivers from the motherboard manufacturer.
Sound card drivers
If after installing the motherboard chipset drivers you continue to have issues install the sound drivers. We suggest you download the sound drivers from the computer manufacturer or motherboard manufacturer.
A listing of motherboard manufacturers and their drivers can be found on our motherboard chipset drivers page.
Aug 30, 2008 | Microsoft Windows XP Home Edition
Usb still dont work
Mar 28, 2008 | Foxconn WinFast K7S741MG Motherboard for...
USB 2.0 (Chipset VIA 8237) ECS P4M800-M7 Unknow Device
Hi, John
The USB 1.1 and USB 2.0 is a big issue regarding technology, the 1.1 has maximum speed of 12 megabits where as 2.0 has upto 480 Mbps. And all USB 2.0 devices are compatible with 1.1. Windows XP Home Edition and Windows XP Professional are both fully USB 2.0-compliant with the correct drivers.
So in your case it must work properly. But if the USB 2.0 from microsoft got currepted or badly updated by some thirdparty USB 2.0 driver then it will not work. I have been faced this problem. After doing some stuff I found that if I uninstall the USB drivers and reinstall it from microsoft driver then it works.
So, just go to the Device manager and un-install the USB drivers, then reboot the system to parmanently delete the removed driver. Then install the driver from Windows XP CD.
good luck
Thanks
Iqbal
Mar 25, 2008 | EliteGroup P4M800-M7 Motherboard
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
129 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
