Question about Goodman GMS90703BXA Heater
I have a 1991-93 Goodman GMP 075-4 furnace. The other night I adjusted the temp to have it kick on, everything sounded okay, it never lit. I have checked the ingniter, it has continuity. WHat else should I possibly look at?
    Guru:
  • 415 Answers
Look at pressure switch and inspect the tubing for any water logging, crimps, or cracks. Also ensure there are no obstructions in the vent line.
Is the ignitor glowing at all? Did you test the voltage going to the ignitor?
I hope you find this information to be very helpful to you moving forward. :-)
Posted on May 10, 2010
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
We need to change the heat exchanger for my Goodman Heat Furnace model no.-GMP 075-3
Not an easy task! Take many pictures as well as draw out and mark which wire went where. You will have to remove everything from inside the cabinet to get to the heat exchanger. It may be easier to replace the furnace. If you are paying a professional to do the exchange, figure three hours if they have done it before, if not figure 5 to 6.
Apr 02, 2011 | Goodman Heating & Cooling
I have a Goodman GMP 075-3 Rev B and cannot find the filter to replace it can you tell me where it is
I have the EXACT same problem. Cant find the filter and no manual came wit hthe furnace when I bought hte house!!! AGH!!
Nov 08, 2010 | Goodman GMS90703BXA Heater
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman furnace\ blower comes on,unasked
Sounds like the fan switch on the furnace is set to low. Turn power off to furnace, take door off of furnace look for a fan switch, it may be a fan - limit together. The limit settings should be approximately 160° to 200°, and the fan settings should be about 100° to 140° set it to 120° it it's already set there then you probably need to replace it.
Aug 03, 2009 | Heating & Cooling
Twinning problem
Switch the leads and also make sure that you have a good ground.
Mar 30, 2009 | Goodman Heating & Cooling
Goodman heater won't stay lit
AA, it could be a lot of things going on or just one little thing. I have atached a link that you can open to get your owners manual for that furnace. Inside there is a diognostic troubleshooting guide that may help.
http://www.dnmech.com/lit/io-244c.pdf
Good luck and let me know what you discovered.
Oct 27, 2007 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
384 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
