Question about Magic Chef CYG2000AWW Gas Dryer
Dryer does not get hot
Dryer spins clothes get dry after a while but dryer does not seem to get hot
  • Magic Chef Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer does not get hot - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Tdryer does not get hot - 2_bing.gifting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 11, 2010
Whirlpool gas dryer (LGR8648PW1) doesn't stop spinning in automatic mode.
More than likely a bad timer assembly. They are usually easy enough to replace if you have basic mechanical skills. The part can be ordered from repairclinic.com.
Jun 26, 2012 | Whirlpool Dryers
Dryer does not dry clothes after 1 hour but seem like its getting hot
it might be the washer it is not spinning as much water out of the clothes as when it was new try double spinning the water out of the clothes
Feb 27, 2011 | Roper REX4634KQ Electric Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Dryer does not dry clothes but seems to be hot inside when i open the door
Most of these guys get a bad blower wheel. The heat melts the hub causing it to spin free and airflow is reduced. This makes it take fifty forevers to dry a load of clothes. More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 18, 2010 | Crosley Dryers
No hot air
clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
May 09, 2010 | Whirlpool LER5634L Electric Dryer
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Magic Chef CYG2000AWW Gas Dryer Logo
169 people viewed this question
Top Magic Chef Dryers Experts
Tim Whalen
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
