Question about Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop
My profile 4 turns on for less than a second and then shuts off help
Mode Silent
Are you asking how to get it into or out of the silent profile? If so, use this trick that works with most cell phones; hold the " # "key for more than 4 seconds and the phone should switch itself to the silent profile. Hold the same key again for another 4 seconds or so and it should switch back to the 'normal' profile.
Hope this helps :o)
Nov 19, 2013 | Cell Phones
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
My gateway profile 4 desktop will not power on. nothing happens when I push the power button. measured 12v at the computer end of power cord. switch look ok. worked fine yesterday.
Remove the power cord and then take out the battery. Hold down the power button for 30 seconds, then plug in just the AC powercord and try turn the laptop on.
If it turns on let it boot into the operating system and then shut it down and put the battery back in.
Hopefully this will resolve the problem but if it doesn't turn on again with the battery in there is a problem with the battery.
Post back if you need more advice.
Good luck.
Jun 27, 2010 | Gateway Profile 4 All In One (MPN...
Turns on for less than a second. then shuts off
Unplug fo a .5 hour let it reset then see what happens when I got mine to fire up the blue side to side convergane wouldnt adjust GOOD LUCK
Jun 13, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
Installing motherboard in gateway profile 4
you need to replace the motherboard if the pc is auto shutting off, maybe even the processor!
May 19, 2008 | Computers & Internet
Toshiba 61 inch TheaterView
Happened to my tv too and i have the same one. Theres nothing you can personally do about it, you got to call someone that repairs T.V's it will cost you about $350.
Jan 05, 2008 | Televison & Video
Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
