Question about Baby Gear
1984 Pontiac Bonniveillie
I Need some help real quick so can someone help me out?
I have a 1984 Pontiac Bonnievillie and I tried to change my carberator and it was the wrong on so I put my regular carberator back on but now my pedal keeps sticking. What should I do??
  • 19,396 Answers
It is the throttle cable, check that is in place both on carburator and on pedal side, If it is disconnected from pedal, pedal stay down if it stays up then cable is too tense, play with it.
Same if it is clutch pedal, but I assume working on carberator you touched throttle not clutch or brakes.
Regards
Posted on Mar 28, 2008
1984 pontiac fiero 2.5l bogs down on excelartion
ok you may be losing fuel pressure get it check but you may need a fuel regulator or a coolant temp sensor
Mar 24, 2014 | 1984 Pontiac Fiero
1984 Honda VF 1100 Sabre fork oil change
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Quick fork oil change
V65 magna fork seal replacement part 1
Honda V65 MAGNA Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Mar 26, 2012 | 1984 Honda VF 1100 Sabre
I have a 1984 Pontiac Firebird. Car was running great, then one day my son started it and he said sounded bad so shut it off. Now won't start and I believe there is fuel in the oil. What causes that?
That doesn't seem to be a likely issue.
Sounds like it could be your starter, if it's not attempting to turn over try tapping the starter with a hammer while simultaneously having someone attempt to crank it over.
If there was fuel in the oil, you'll need to immediately drain the oil and change the oil filter. I would also recommend replacing with synthetic oil.
Feb 16, 2011 | 1984 Pontiac Firebird
What are the steps to reset idiot lights on dashboard for oil change?
turn key on push gas padel to the floor three times real quick and it should flash and reset....hope it helps
Nov 23, 2010 | 2003 Pontiac Grand Am
What is the firing order for a v8 1984 pontiac
firing order is 1-8-4-3-6-5-7-2 distributor rotation is clockwise with cylinder 1 on the cap being toward the front of the engine, a little to the left as seen from the back of the engine. Sorry don't know how to attach graphic
Mar 05, 2010 | 1984 Pontiac Grand Prix
I have a 1987 pontiac trans am with a 350 tpi that needs to have the sparkplugs changed but the space is very limmited on both sides of the engine. does anyone have any idea on how to make the job easier?
IF YOU USE THE SPARK PLUG SOCKET AND A 5/8" WRENCH ON THE END OF IT TO TURN THE SOCKET, YOU CAN GET IN REAL CLOSE. IF YOU USE A RATCHETING BOX WRENCH, IT WILL GO REAL QUICK. A UNIVERSAL ADAPTER WILL ALSO HELP. THIS CAN BE FOUND AT MOST AUTO PARTS STORES FOR A COUPLE OF BUCKS. HOPE THIS HELPS. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING TOO. PLEASE LET ME KNOW IF I CAN FURTHER ASSIST YOU. BEST OF LUCK.
Aug 22, 2009 | 1987 Pontiac Firebird
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
