Question about Hitachi 50V720 Television
Green power light, red temp, & red lamp light flash in sequence
Hi my name is Henry. I have a Hitachi 50V750. It was doing OK.
I did get the blue line that eventually took over the whole screen.
Now while watching, the TV stopped dead (audio & video).
Now when turnung the TV on, the green power light, red temp, and red lamp light flash in sequence.
What does this mean? Is it the bulb shot?
If it's just the bulb, would I still have audio or are there other problems?
Regards,
Henry
daniel719
  • 240 Answers
SOURCE: Hitachi Model #50V720 50 '
ther is only one lamp bulb to change.
see your users manual to change it.
Posted on Jan 09, 2009
  • 5 Answers
SOURCE: Black Screen
You may have a fan that is not spinning fast enought and a overheat condition is occuring or you may have a bad lamp.
Posted on May 02, 2009
SvenBosch
  • 3 Answers
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
Posted on May 30, 2009
SOURCE: Hitachi 50" Plasma (P50X01AU), power light comes on but no screen
Hope you already resolve it, if not, here what I went through 1. Try to get a service manual for your model ($10-18) from http://www.service-docs2.com or similar place. 2. Open the back and follow instructions how to remove and test the SDR-D and SDR-U board on the far left (take one off, see if you could see half the picture). Inpsect the chips on those two boards, you might be able to spot the burned out holes (that would be the defected board, seemed to be a known issue for particular models) 3. If it is the board, go to ebay and get the pulled out board replacement ($70-90) I fixed my 50 inch plasma this way
Posted on Jun 12, 2009
jan mczeal
  • 632 Answers
SOURCE: Hitachi Plasma HDTV turns off by itself. indicating lamp flashes.
The unit senses a fault in the power circuit. It is either in the power supply unit (PSU) peripherals or in the PSU itself.
  • One of the peripherals might be loading down the PSU causing it to shutdown.
  1. Check the power input terminals of the peripherals for any short circuit using an ohmmeter.
  2. Replace any part found to be causing the issue.
  • The power supply unit cannot run under load and shuts down. It is usually caused by bad capacitors.
  1. Check the PSU board for any bad capacitor.
  2. Replace bad capacitors with the same specifications.
  3. Make sure to replace the capacitors in correct polarity.
  4. Bad capacitors look like these:3a72a3c.jpg17dffa0.jpg
Posted on Nov 03, 2009
No sound, no picture.
Hitachi DLP Television Bulb
Most likely a bad lamp. I would replace it first to make sure.
Sep 06, 2015 | Hitachi Televison & Video
Tv will not power up blue power light flashing,red temp and red lamp lights flashing
The lamp is likely blown - it is loacated behind the front panel and can be pulled out to check - unplug set and do not touch front of lamp.
Oct 11, 2009 | Hitachi 50C10 LCD TV
TV went off, and three lights come on (green "power", red "temp", and red "lamp")for just a second, in succession from left to right.
My television had two red lights flashing, one for Temp and the other for the lamp. I removed mythe lamp assembly and the bulb filament was burnt out. I order a new lamp and housing unit UX21517 and replaced it and now I have the red light flashing which is calling out the lamp again.
Oct 10, 2009 | Hitachi 50V720 Television
Hitachi 55" when I turn it on the screen is blask and no sound.
first step to take:
refer to the user's manual to find: How to replace the lamp?
and second replace the lamp. www.andrewselectronics.com. prefer original ones.
Mar 29, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V720 Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
