Question about GE Tritonr XL GSD6260JCC Dishwasher
Cloudy film on plastic items
The dishwasher has been working fine with Cascade and Jet Dry. The last two loads resulted in plastic items (trim on coffee pot, plastic handles on paring knives, etc.) having a cloudy film. The glass items are clear and just fine.
5 Suggested Answers
706Cajun
  • 34 Answers
SOURCE: dishes have cloudy film on them
Try this. I want you to run your dishwasher empty, on the hottest water setting. Let it fill and just before it starts the wash cycle put in three cups of white vinegar. I expect your jets are clogged and the vinegar should hopefully open the jets back up. You don't need to add soap during this cleaning process. Works just like when you clean your coffee maker.
Posted on Apr 23, 2009
  • 677 Answers
SOURCE: Cutlery is cloudy and dirty,
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Posted on May 10, 2009
  • 457 Answers
SOURCE: Film on glasses and dishes.using cascade complete
make sure when you fill the jet dry that you make sure it is completely filled. you must add jet dry,close door,lower and raise the door 3 times and then check normally you could add more jet dry because the air is now pushed out by this process. and finally b4 you turn on your machine make sure tolet your faucet run until it hot and then start machine. that should handle the problem. let me know if this helps by sending me a 4 thumbs up post . thanks
Posted on Mar 01, 2010
clrvuedoc
  • 175 Answers
SOURCE: my glassware is coming out cloudy! the dishes are
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Posted on Mar 01, 2011
How did I get the film off my glassware? My glassware has a thick film that is very unappealing. I have to hand wash them. I use cascade detergent.
If you are not using a water softener use a rinse aid such as Jet Dry. This will help to eliminate scum on glassware. Use the solid form of Jet Dry. If you use a water softener you need to decrease the amount of detergent.
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Mar 12, 2011 | Whirlpool Dishwashers
We purchased this unit in 6/10. It leaves a film on my plastics and does not get my dishes clean (glasses, silverware). I use Cascade complete and jet dry. I don't know what is wrong. Please help.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Feb 07, 2011 | KitchenAid KUDS30IVWH Builtin Dishwasher
There is a film like residue on dishes after complete cycle has ran. I use cascade tablets and also have refilled the jet dry. It is on all dishes but the glasses and clear plastic show it the most.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
We have a bosch she4am dishwasher and just recently the unit doesn't rinse all the soap out of the glasses of the top rack and also a film is being left on the dishes. i have checked the top spinner and it...
check the top of the cabinet after the unit has started to wash the water droplets is the key. if you see water droplets on the very top all over then the unit circulation pump is working. If that checks out then check the jet dry compartment. here is a trick.
open the compartment door, fill compartment until it cant hold anymore liquid,close compartment door,lower and raise the door 3 times,open compartment door check to see if you fill with more jet dry,repeat this process untill it cant take anymore.
what this does is removes the air out of the compartment. this will last for about 10-12 washes. last thing is to turn your faucet water on until it is the hottest then start your machine. use cascade soap and no tablets. when you use tabletrs with jet dry the machine over suds, the rinse aid compartment or dispenser is vidal to drying,cleaning spots and film. hope this helps.
Mar 13, 2010 | Bosch SHE4AM06UC 24 in. Built-in...
Dishes have cloudy film on them
Apr 23, 2009 | GE Dishwashers
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Kenmore 587 leaves a cloudy film on everything
sounds like the pump motor or impeller are toast.does the unit sound like its not pumping the water like it used to?
Aug 09, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
GE Tritonr XL GSD6260JCC Dishwasher Logo
309 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
