Can you tell me why my monitior shuts off when I leave the computer on. This has happened numerous times
  • 4,737 Answers
Simple, your monitor power is set to turn off automatically at the particular time (maybe 5 mins, 10 mins, 1 hour etc...) You can reset this by following the steps below: For XP)- 1. Right Click on the Desktop - Properties - Screen Saver - Power - Turn off monitor and set it to Never. More or less similar with Vista and Windows 7, Good luck.
Posted on May 10, 2010
While driving check engine light comes on sometimes stays on 5 minutes other times few seconds then goes off does not happen everyday. The problem when I go to have it checked light does not come on and I...
Check fuse box it has two ECM fuses one is power for the computer and turns off and on with switch the other is for computer memory check fuses if both fuses are good And computer still has no memory i think your going to find ECM problems. I Have bought many computers from wrecking yards and saved a lot of money. The persom adviseing you there is no memory is sadly mistaken but thats ok. One other thing I wish you would try is to disconnect battery for about one minute. setting the computer to factory specs try that and see if it changes anything. all computers have memorys sence mid 80s next time your engine light comes on go to Auto Zone and get it checked but dont turn the car off leave running
Mar 22, 2011 | 1995 Ford Taurus
A hole was poked in my oil Pan from a speed bump at work so when I cranked it to leave it automatically shut the car off but when I got the oil pan fixed ever since then the check engine light has been on...
I think the problem would be your ecu memory got that poblem in the memroy.
You go back to the dealer and tell them to reset the memory of the ecu/computer.
Then tell what happen........
Hope that solve your problem!
Thanks for using Fixya!
Dec 12, 2010 | 2008 Chevrolet Cobalt
When i turn on the computer i can hear the computer opening but the monitor does not open, sometimes it flickers then black. I have to play with the power button several times to get the screen to come up....
just check out by your rams. because tyhe problem may be with the rams .if the rams are working fine just connect the monitior to the opower socket.do not connect the monitor to the cpu .if the monitor switches on perfectly thenthe problem is with the motherboard .
Oct 03, 2010 | Computers & Internet
Had the clutch replaced car starts find but will shut off
NUMEROUS POSSIBLE CAUSES! Does the Check Engine light come ON when this happens? Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there.
Jun 16, 2009 | Hyundai Motor 2002 Elantra
Scanning
Scanner unit has failed. It costs as much to replace it as a new printer.
Mar 05, 2009 | HP PSC 750 All-In-One InkJet Printer
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
Computer reboots after I shut down
Hi there...
              MMMMMmmmmmmmm can you be more specific ? has it recently started to do this or has it done this since you purchased the computer ? Are you trying to shut it down from the windows shutdown menu or are you pressing the power button to let windows shut it down ?? I Need more information before I can help you work out whats going on with your computer ...If its only just started to happen you may have a virus or a trojan infecting your system or your bios has become corrupted.The windows registry may have become corrupted or your power supply is faulty...the problems that could cause this are numerous , please be more specific about how you are shutting the computer down..
Aug 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Computer shut off
you have a hardware conflict or a bad power supply/MB. or a bad video card/driver. or a bad RAM chip. uninstall everything but one chip, one HDD and CDROM, and one video card. install the OS rom there... then add items until it becomes unstable. the last thing you installed is the bad boy.
May 22, 2008 | Samsung DLP HL-P5663W 56" TV
Blank monitior
There is probably some electronic malfunctions inside your monitor. Since I will not be able to actually check your monitor, the best solution for this is bring your monitor to a qualified TV/CRT technician in your area for proper diagnosis. He's the right expert and the second opinion to that kind of problem. Problems regarding inside the monitor are usually not fix-it-yourself kind of thing for non-expert like you compared to software problem, which can be mostly fix by yourself guided by an expert.
Sep 12, 2006 | HP Pavilion MX70 17" CRT Monitor
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
