Question about Philips Televison & Video
I have a 50 inch Phillips dlp with no color and the lamp is fine. Tv techs are sayin they can't order a colorwheel either.what do I do? 7302ph5 is the sku, model# is 50pL9126d/37.please help!,,, broke and bored.
SOURCE: sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Posted on Apr 11, 2008
SOURCE: 50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Posted on Mar 23, 2009
  • 35 Answers
SOURCE: my DLP tv will not turn on the power button flashs
have you changed the lamp? J.D.W.
Posted on Jun 18, 2009
SOURCE: I have a Phillips 50pl9126d/37
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Posted on May 17, 2010
  • 5 Answers
SOURCE: How hard is it to change the lamp in my Phillips DLP TV
remove the screws (12) holding the lower back on. loosen both silver screws on the left side of the lamp assy. pull out assy. using the small silver handle located on the assy. body.
Posted on Sep 13, 2010
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Oct 12, 2009 | Philips 50PL9126D/37B 50" DLP TV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
Phillips DLP 50 inch has no color great black and white picture
There is no color chip. What it does have is called a motor driven color wheel. The problem is that the color wheel is no longer spinning to produce color. Replace the color wheel and you should be fine.
Dec 31, 2008 | Philips TV Tuner Video Capture PCI Card -...
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Televison & Video Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
