Question about GE 13GP341 13" TV
Turn mute off without remote
Tv is on Mute how to take it off of mute without remote ?
Tv on mute no remote how can I turn mute off
If you have no volume control on the main TV, unplug the TV and then turn it back on. The mute should be cancelled. If you have a volume control, turning it up should cancel the Mute function. It does on mine.
Nov 02, 2015 | Televison & Video
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
We have a DVR hooked up to our 1989-99 Mitsubishi TV (floor model) still in amazing working condition. The remote control for that TV never allowed us to put the TV on mute. If the mute botton was...
Well, without knowing the exact model of tv and remote, I can just give my best guess.
Try using the volume up/down on the TV and / or the remote.
On the TV, try pressing both the volume up and down at the same time.
Stick the remote right in the face of the TV (direct in front of the remote sensor) and hit the mute button.
Try tapping the mute button in very short single bursts rather than pressing it for a half second like you would any other button.
If any of those work, please come back and reply with the model of the TV and remote, because someone somewhere probably has the same issue and would love to have it solved!
Feb 24, 2011 | Mitsubishi Televison & Video
Get TV off of mute setting without using remote
Maybe if you push the volume button on the front of the tv.
Jun 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv on mute
turn the tv off at the mains leave for 10 - 20 mins the turn back on, this should solve your problem.
Mar 10, 2009 | Panasonic TX-28DK2 TV
TV TURNS ITSELF OFF WHEN MUTE IS ACTIVATED
Try a different remote, your remote may be putting out the wrong command when you press mute. Will pressing mute turn the TV on?
Feb 05, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
How to remove mute without a remote controller
sorry but there is not a reset button and it looks to me as a damage chip is truth that tere is a mute option in your vcr but I have fix that problem before and was a bad chip look for a teh to help you but remember a new vcr cost is verry low so dont spend to much in that one..good luck
Aug 05, 2006 | Akai VS-J200EA VHS VCR
GE 13GP341 13" TV Logo
512 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
