Question about GPS
Need wire spec for panasonic radio - GPS
  • 8,197 Answers
May I get the model # of the radio so I can get you the right wireing diagram.
Posted on May 13, 2010
I need a diagram to wire panasonic cq-c5301u in a 97 f150
Google your radio model # and get wiring diagram for radio.
Google your vehicles stock radio wiring diagram to get that info.
Put them together........BAM....Music!
Nov 12, 2016 | Panasonic Car Audio & Video
Can you play a mp3 on this radio and if so how
According to the specs it can play MP2 and MP2 music files,
You can check the specs from this WEB site.
http://shop.panasonic.com/shop/model/SC-HC27?t=specs
You need to copy the MP3 music files to an USB memory stick and connect it to the Panasonic then select the USB memory stick music file to play.
May 12, 2013 | Panasonic Sc-Hc27 - Micro System - Radio /...
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
I need the wiring connections
Have a look here
http://www.tehnomagazin.com/Auto-radio-car-connector/PANASONIC-Car-Radio-Wiring-Connector.htm
Oct 17, 2009 | Panasonic CQ-DF100 CD Player
Does the radio on a 2003 pontiac vibe have an rca plug in the bac
Usa spec Ipod adapters usually interuppt factory wiring harness.... rca plug on Usa spec is usually for aux input (line level input)... USA spec is a good piece though provided its application is correct for your vehicle, look up your car on crutchfield.com to be sure
Apr 08, 2009 | USA Spec Ipod Interface Gm
Wanted Wiring diagram panasonic car radio tape player p114
if the panasonic radio is a factory model, check with a GOOD car audio shop. they can get you the factory wiring harness to plug in, along with the diagram. if the panasonic is a replacement, like a jensen or kenwood, check out CSK Auto or AutoZone for a factory harness adapter. it makes life so much easier...
Feb 01, 2009 | Panasonic Car Audio & Video
Japanese import integra type r stereo wiring diagram
Try the following, this is an 1997 USA Integra
Radio Constant Wire 12V+: Blue/White
Radio Switched Wire 12V+: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Left Rear
Front Speakers Size and Location: 5 1/4′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Front Speakers Size and Location: 6 1/2′ Side Panels
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Oct 06, 2008 | 1997 Honda Accord
Thermal fuse
i purchased a NTE8115 from my electronics supplier, closest I could find.  Radio shack also has them.
Sep 25, 2007 | Panasonic PT-40LC12 40" Rear Projection...
GPS Logo
20 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
