Question about RCA P52921 52" Rear Projection Television
I have a 1999 rca modle# 52923 that shuts off on its owe and mite take a week before it will turn back on
61"RCA Scenium modle number d61w136d When turning
You are on the right track, if the lamp is not lighting bright enough it could do this exact thing, the three tries is standard on RCA products, called the 3 strikes and your out---set will try 3 times to make it on and then shut down.
The color wheel while possible usually makes a high pitched fan like sound and with lamp out you should be able to see it to know if missing parts of the wheel or shattered.
12_18_2012_8_04_57_pm.jpgtypical color wheel.
Dec 18, 2012 | Televison & Video
Turns on then shuts off
Set is protecting itself---called shutdown.
You have a short or open somewhere---what is your skill level with this kind of equipment?
Dec 08, 2012 | RCA Televison & Video
I have an RCA universal remote. Modle #RCR311W.
This is a link to your RCA RCR311W universal remote users guide. This download is in .zip format, and needs to be unzipped (extracted) with winzip or other program. Then it can be viewed using Adobe Reader (.pdf). Codes are located in the back of guide.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr311&kw=&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr311-manual.zip
Oct 27, 2009 | RCA Universal Remote Control
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
Need new engine 1999 Corolla
what part of the world are you in? and which engine is in it (engine code/vin/ or emissions tab info)
Dec 16, 2008 | 1999 Toyota Corolla
RCA D52W119 Projection tv
You have 3 capacitors on deflection board ,ck them cp150,cp111 cp114.cp150 2200uf 15v green/gold writing.
Oct 13, 2008 | RCA D52W19 52" Rear Projection Television
I have a rca 27 inch tv modle # 27v514t sdTV.when i turn it on 2 or 3 seconds it shuts off
The cable running from the button on the front unplug it as soon as you get the tv to turn on it should stay on.
Jul 28, 2008 | Televison & Video
RCA P52921 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
